check engine light prbmz
Old Feb 11, 2004 | 09:59 PM
nexus da9's Avatar
Default check engine light prbmz
i have a prbm with my check engine light... i was told it only deals with emissions... and so i changed my cat, got 2.5 in. piping from the cat to the exhaust, and changed the exhaust back to stock... i can drive for awhile, bout 1/3 a mile.. then the light goes on and my rev meter is restricted to about 3300-3400 RPM... what could be the cause of this? any possible problem suggestions is greatly appreciated
Old Feb 11, 2004 | 11:15 PM
slowww b18b1's Avatar
Default Re: check engine light prbmz (nexus da9)
did u check ur O2 sensor?
Old Feb 11, 2004 | 11:40 PM
timmy8151's Avatar
Pull the code and see what's wrong.
Old Feb 12, 2004 | 07:53 AM
ofl's Avatar
ofl
Default Re: check engine light prbmz (timmy8151)
Try and reset it. There should be a button underneath your dash that you push and hold and also try to un-do your negative terminal on your battery for about 15 minutes and put it back on
Old Feb 12, 2004 | 08:32 AM
DOHCon15s's Avatar
Default Re: check engine light prbmz (ofl)
no that button is for your maint req. light. Check the manual
Old Feb 12, 2004 | 09:48 AM
nexus da9's Avatar
Default Re: check engine light prbmz (B18B1-turbo)
wherez the O2 sensors located at?
Old Feb 12, 2004 | 11:53 AM
onlyNls's Avatar
Look above your cat, you should have seen it if you changed your cat. What year is your teg anyway?
Old Feb 12, 2004 | 12:10 PM
sickbling's Avatar
have you ran the codes?
Old Feb 17, 2004 | 08:34 PM
nexus da9's Avatar
Default Re: (sickbling)
i've heard about these things called codes... what r they n where could i find em?
Old Feb 17, 2004 | 08:49 PM
thaiphob's Avatar
Nikon!!!
Default Re: (nexus da9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexus da9 &raquo;</TD></TR><TR><TD CLASS="quote">i've heard about these things called codes... what r they n where could i find em?</TD></TR></TABLE>
pull out your ecu and watch the blinking LED. count the intervals and come back.
Old Feb 17, 2004 | 08:55 PM
cu3tip's Avatar
reset ur ecu
Old Feb 17, 2004 | 09:09 PM
thaiphob's Avatar
Nikon!!!
Default Re: (cu3tip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cu3tip &raquo;</TD></TR><TR><TD CLASS="quote">reset ur ecu</TD></TR></TABLE>
now how is this going to help him find the CEL code
Old Feb 18, 2004 | 05:19 AM
IntegraB18's Avatar
Default Re: (thaiphob)
get a book and run ur codes and see what it is...my guess it sounds like something is wrong with ur dizzy......i had the same problem with my car....it wont let me go over like 3500rpms....the main shaft in my dizzy had a alot on chipped off teeth...so look into that
Old Feb 25, 2004 | 06:28 PM
nexus da9's Avatar
Default Re: (IntegraB18)
whew, thanks alot, i've been hella confused these past weeks kuz ignorant people can't really give me at least ideas of what's wrong with my integ... thankz.
Old Feb 25, 2004 | 06:45 PM
Huh_oh Shit!'s Avatar
You can go to Autozone and they can check and see what the check engine light is telling you for free.
Old Feb 26, 2004 | 04:57 PM
nexus da9's Avatar
Default Re: (Huh_oh ****!)
i heard they could only check OBD1 or OBD2... i have OBD0... =\... know a place where they could do it then?
Old Feb 26, 2004 | 05:34 PM
gsrjimmy's Avatar
to check it you just get to your ecu and look at the blinking light and count the sequences short blinks are 1s and long blinks are 10s
Old Mar 2, 2004 | 03:36 PM
nexus da9's Avatar
Default Re: (gsrjimmy)
thanks, i'll be back sometime soon with those results
freddysEF
Feb 11, 2008 08:59 PM
everlasting1832
Feb 10, 2005 11:23 AM
Nitto
Aug 10, 2004 07:11 PM
pbizzlegsr
Apr 4, 2004 11:46 PM
Ludeboi
Aug 31, 2002 04:54 AM
