Check engine light is on all the time
Old Feb 13, 2005 | 03:23 PM
BolivianDc2's Avatar
Default Check engine light is on all the time
https://honda-tech.com/zerothread?id=1150145
Modified by BolivianDc2 at 1:58 PM 2/15/2005
Old Feb 13, 2005 | 03:35 PM
Outkast95LS's Avatar
Default Re: Check engine light is on all the time (BolivianDc2)
what code is it throwing?
Old Feb 13, 2005 | 04:33 PM
Default Re: Check engine light is on all the time (Nine5IntegraLS)
its not throwing any codes, the light comes on and stays on even with jumping the connector above the ECU
Old Feb 13, 2005 | 04:38 PM
blkb18's Avatar
Are you jumping the blue conector?
Old Feb 13, 2005 | 04:44 PM
Default Re: Check engine light is on all the time (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">Are you jumping the blue conector?
yea
i'm running hondata s200 also, p28 ECU and OBD2to1 harness
Old Feb 14, 2005 | 07:55 AM
ok, i just cut the j12 jumper and checked the code. It looks like its 16 (fuel injectors) but the check engine light is flashing way too fast then it should be. It's at around double speed what it normally is when flashing codes.
the saga continues....
ethos0518
Aug 13, 2011 07:36 AM
lifes_simple
Honda Civic (2001 - 2005)
Jan 28, 2007 12:43 AM
sublimenerd
Oct 19, 2006 09:11 PM
KillaBk
Oct 29, 2005 06:00 PM
afterburners
Feb 2, 2004 05:18 AM
