check engine light!!!
Old Sep 3, 2009 | 08:38 AM
vinceiscoo's Avatar
Default check engine light!!!
i listen to my friend and washed down my motor
i covered the distributor and alternator
and power washed it
the next day i let the car warm up the check engine light start flashing
then after a hour i started my car again and the car started to shack so i took it to my friends house to use the ob2 reader, while i was driving the car would jerk alittle then while i was stop it would shack
when i got to my friends i took out my skark plug wires and found out there was water
i took all plug wires and let it dry then i took out the plugs itself and crank the motor to see if any water got in
cleared off the check engine
with in a hour of driving/50 miles the check engine came on again, went back to my body
and it said the 4th cylinder had miss fire
so i changed out the spark plug from the fourth to the first to see if it was the plugs
what else should i do? and could it be any other issue?
Old Sep 3, 2009 | 10:53 AM
8zero8's Avatar
Default Re: check engine light!!!
change the rest of the plugs.. check the distributor..
Old Sep 3, 2009 | 01:21 PM
jdmjoka's Avatar
DB squad #282
did u have the car running when u did this? i hear your suppose to.
Old Sep 3, 2009 | 01:23 PM
8zero8's Avatar
when u change the plugs??
Old Sep 3, 2009 | 01:56 PM
egsleepercivic's Avatar
think he means when you spray the engine.
happened to me the first time I did my b16 , get new plugs, take out the old plugs let it dry out for a while, you can turn it over a couple of times with the plugs out, then replace the plugs and you should be good if your going turn it over with the plugs out I would disconnect the wireharness for the dizzy b4 you start cranking
gl
also I learned if you jack up the drivers side of the car a little it will help the water drain without getting into the plugs
Old Sep 3, 2009 | 02:11 PM
Boosted_DC2_686's Avatar
i'm having this same problem. please help!
8zero8's Avatar
oh, k that makes more sense.. never heard of jacking the car up though.. seems like alot of work to spray the engine bay
Old Sep 3, 2009 | 03:19 PM
PHAT-INTEGRA's Avatar
I always spray my engine bay I only wrap the dizzy with a towel. Never had a problem. Been doing this for 10+ year. I use the water from my parants house or the coin car wash.
Old Sep 3, 2009 | 08:28 PM
vinceiscoo's Avatar
yea i think ima take out all the plugs again and disconnect the dizzy and crank it again
and i think ima change the spark plugs
one last question how would you clean your motor cause i got my car from the auction and it was really really dusty
my other friend told me to cover the dizzy and alternator and use the tire degrease from the coin machine at the car wash (thinks its a good idea) dont wanna mess up again
thanks for all the great replys
Old Sep 3, 2009 | 08:45 PM
__oversea's Avatar
when i pressure washed it, i did not cover anything. and never had a problem. (with engine running)
Old Sep 3, 2009 | 10:22 PM
vinceiscoo's Avatar
so your saying leave the engine on?
Old Sep 4, 2009 | 11:23 AM
8zero8's Avatar
yeah... and how about not directly on the obviously bad areas.
Old Sep 4, 2009 | 02:11 PM
Step to clean the engine bay
1. While motor is off (let the motor cool down or even cold is better).
2. Wrap Dizzy
3. Spray degresser. I like to use orange blast because of the orange citrous.
4. Let it set for about 5min or so. You can brush it with a soft brush if you desire.
5. Wash engine bay with water.
6. Dry engine bay with a towel or some sort.
7. Start motor. once it get to normal temp, you will see steem, it's ok it's just water vap.
I never cover the battery or alt. Make sure your spark plugs are intact fully before you spray your motor down.
Old Sep 4, 2009 | 08:15 PM
vinceiscoo's Avatar
thanks for your help.
sawright
Aug 20, 2013 01:46 AM
93 DET
Feb 14, 2012 12:36 PM
jdmsleeper12
Jul 27, 2009 10:54 PM
ReubesBB6
Jul 13, 2009 11:51 AM
1CleanLS
Apr 9, 2005 07:39 PM
