Honda S2000 Honda S2000
Check Engine light
Old Aug 1, 2005 | 05:15 PM
10KrpmS2K's Avatar
Default Check Engine light
Iwas wondering if anyone knows if there is a way to turn off the check engine light w/out a scan tool. I unhooked the map sensor on the throttle body when i was putting on my charge pipe and accidently started the car w/ it unplugged and threw the light! Anyone?
Old Aug 1, 2005 | 05:28 PM
-L@ndry-'s Avatar
Default Re: Check Engine light (10KrpmS2K)
pull the back up fuse or try to disconnect the battery
Old Aug 2, 2005 | 09:50 PM
ken-e's Avatar
Default Re: Check Engine light (jdm5lug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm5lug &raquo;</TD></TR><TR><TD CLASS="quote">pull the back up fuse or try to disconnect the battery</TD></TR></TABLE>pulling the fuse for about 30 seconds is better since you wont loose your radio settings.
Old Aug 9, 2005 | 07:21 PM
ajdaddi's Avatar
Disconnect the negative on your battery for a few minutes, that should do the trick!
Old Aug 9, 2005 | 07:32 PM
GEN2TEG's Avatar
Turn the car to accessory. Remove the 7.5 "Backup" fuse, under the steering column in the fuse box. Turn the key to off, then put the fuse back in, turn car back on to accessory, and you should not see the light anymore.
Goodluck.
Old Aug 11, 2005 | 07:36 PM
Razor's Avatar
Default Re: (GEN2TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TEG &raquo;</TD></TR><TR><TD CLASS="quote">Turn the car to accessory. Remove the 7.5 "Backup" fuse, under the steering column in the fuse box. Turn the key to off, then put the fuse back in, turn car back on to accessory, and you should not see the light anymore.
Goodluck.</TD></TR></TABLE>
go with this.
Cdeese910
Oct 25, 2012 07:56 AM
gsilnc
Jan 16, 2009 04:16 AM
jdmunzip
12
Sep 4, 2006 08:47 PM
sickofitall1113
Aug 20, 2005 10:56 AM
awalk2005
Jul 10, 2003 12:18 AM
