Check engine code 43, Left Fuel Supply system????
Old Sep 26, 2006 | 08:25 AM
str8JDMteggy's Avatar
Default Check engine code 43, Left Fuel Supply system????
I have a check engine light come up on my 94gsr and it was code 43. I looked it up and its the Left Fuel Supply System. What is that!?
Thanks in advance,
Chris
Old Sep 26, 2006 | 03:37 PM
Anyone know what the left fuel supply is?
Old Sep 27, 2006 | 02:15 PM
anyone
Old Sep 27, 2006 | 02:19 PM
jdmdc2jeff's Avatar
Default Re: (str8JDMteggy)
man was there a (P) in front of the code?
Old Sep 27, 2006 | 05:18 PM
no (p) in the front. Mabye the fuel supply system is a stupid way of sayin fuel pump?
Old Sep 27, 2006 | 07:26 PM
JasonST's Avatar
If i remember right code 43 means u got a problem with eather ur injectors, egr, fuel relay or pump. Do u have any severe problem when driving or does it appear to drive fine?
Old Sep 28, 2006 | 05:52 AM
Rhythmsnewsn's Avatar
Default Re: (JasonST)
I got the same code before, make sure you o2 sensor is working properly. my code 43 ended up being the o2 sensor. and for a universal bosh at 20 bucks? might as well replace it.
Old Sep 28, 2006 | 02:13 PM
Yes the car drives with no problems at all. Occasionaly it will randomly not run. I will get in the car start it and it will start up then stall, then i start it and it will stall, then it wont start for like 2 mins. After that it will start and run perfect. Is my gas mileage bad i get around 240 miles to the tank? Thanks again.
Modified by str8JDMteggy at 9:28 AM 9/29/2006
Old Sep 29, 2006 | 08:27 AM
any ideas
burfy
14
Nov 16, 2011 07:53 AM
jdm206
13
Dec 6, 2007 01:06 AM
JDM_EH2
14
Oct 1, 2005 01:32 AM
cincispeedemon
Nov 22, 2004 05:51 PM
RoAnSa
Jun 30, 2003 04:37 PM
