Check Engine 22 problem help
Alright i've searched on many forums and tried tons of way to solve the check code 22 problem. I checked oil level and its good which i pour extra over the dots, resetting ecu, cleaning out the solenoid, and even rewiring the vtec. No dice! I can't get it over about 6k and its without vtec. So i checked on the bypass for a4(solenoid)to d6(pressure) and it works vtec engages but the code for the pressure is still there. I reset the ecu and it keeps coming back. Is it suppose to disappear?
