check code 6 engine coolant temperature ETC
Old Mar 17, 2005 | 02:51 PM
InTeGrA B18b1's Avatar
Default check code 6 engine coolant temperature ETC
Hey guys, I just recently took my turbo off and now i have a code 6. I tried resetting my ecu but that did not work. I am wondering if you guys know what i should do. I searched but had no luck. thanks
Old Mar 18, 2005 | 11:26 AM
Default Re: check code 6 engine coolant temperature ETC (InTeGrA B18b1)
bump, everything is plugged in.
Old Mar 18, 2005 | 12:34 PM
stareatsun's Avatar
replace the switch. its in the head right near the lower rad hose.
Old Mar 18, 2005 | 12:38 PM
Yambor's Avatar
Default Re: (stareatsun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun &raquo;</TD></TR><TR><TD CLASS="quote">replace the switch. its in the head right near the lower rad hose.</TD></TR></TABLE>
Yes, replace the switch, BTW its call ECT Sensor... Its on the head next the the radiator hose. It is not the small sensor, but the rather large one, that actually has a harness plug going to it. Not the one that sends the signal the the gauge cluster inside the car..
goldfinger93030
16
Jul 8, 2009 08:04 PM
waciii
Oct 26, 2008 06:57 PM
snowblind7x
Feb 5, 2008 06:21 PM
1PT-SICK
Oct 23, 2007 07:39 PM
court
Jun 8, 2006 02:06 PM
