CEL Code 90
CEL Code 90
Last night Code 90 came on, which is
Evaporative Emission Control System leak detected in the fuel tank area
I checked my gas cap, it was on tight(I always do 3 clicks). And it's still on, even after a long drive to work. What should I do.
Re: CEL Code 90 (SilverB18C1)
Do a search, I had an old post with the same CEL 90 problem. My light is still on, but it could be several things:
gas cap
EVAP canister under the battery, check the connections
Cat. Converter
NOt sure, which is wrong on mine, don't have the $ to fix it right now. Let me know after you troubleshoot if you fixed it.
gas cap
Cat. Converter
Re: CEL Code 90 (laNk_LinK)
gas cap
Cat. Converter
gas cap
Cat. Converter
Reset the ECU and see if it comes on again. If it persists, take it to the dealership.
A friend's ITR had the same code. They either replaced the gas cap or the EVAP two-way valve. Can't remember.
Re: CEL Code 90 (IN VTEC)
Silver B18...let me know how you fixed it, I think my cel code 92 is a similar problem and I want to know how much the EVAP parts cost
Thx
Thx
hmm i just reset the ECU and the CEL is gone. ill find out for sure tomorrow on the drive to work to see if its gone for sure. ill keep ya posted
After you reset it, it takes 2 days for it to come back on. At least that's what happened to me.
well so far so good. after my 70 mile drive to work the CEL is still off.
Until it comes up again, there's no case and really no point to bring it to the dealer....unless there's a specific recall on whatever part(s) that are affecting it.
grrrrrrrrrrrr this is fawking pissing me off, honda/acura doesnt do diagnostics on saturdays. grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr and theres no wat for me to take it on the weekdays. you think think i should just go pick up a new gas cap and see if thats the problem? if not them im stuck
