CEL Code 67 with leakage
Old May 21, 2005 | 10:03 PM
Sukii's Avatar
Default CEL Code 67 with leakage
Alright, so i just installed a JDM header 4-1 with T1r exhaust and a cat ordered from SMSP. The car is leaking from the muffler to the s-pipe and i haven't been able to check if its leaking from the s-pipe to the b-pipe. I believe that the connect from the header to the cat is not leaking. After installing everything (with a leak) it seemed to drive fine, no CEL or anything. When i was test driving it, i gunned it once to see how it felt and no CEL or anything. Now later i went on the freeway was in fifth, rev matched down to 4th then down to 3rd and then i gunned it to 7900 and changed to 4th then directly to 5th. Next thing i know, i see a CEL and it was code 67. Any ideas what it might be (keep in mind, i might have 2 leaks and i dont know if that oculd be the problem) I plan on getting the leaks fixed tomorrow.. is there anyway i can buy gaskets for the muffler to s-pipe and s-pipe to b-pipe connectoions? Any help is appreciated, thx.
EDIT: i know that cel 67 means the cat, but i dounno why there would be a problem
Old May 22, 2005 | 01:27 AM
Sukii's Avatar
Default Re: CEL Code 67 with leakage (Sukii)
anyone?
Old May 22, 2005 | 01:03 PM
Sukii's Avatar
anyonew?
Old May 22, 2005 | 05:05 PM
Sukii's Avatar
come on, nobody?
Old May 22, 2005 | 08:29 PM
tub_sephiroth's Avatar
A leak way down by the s-pipe should not throw a cel. There must be a leak by your cat. Double check there.
2000siturboR
Jul 3, 2008 08:54 AM
Try2Live4God
May 20, 2007 08:07 PM
Sukii
May 22, 2005 05:44 PM
gsrboi80
May 9, 2004 07:24 PM
