CEL after VAFC install
Old Oct 20, 2003 | 06:41 PM
citrus3000psi's Avatar
Default CEL after VAFC install
Ive had a vafc installed for while, but ive never adjusted the fuel trims. Until now becuase I put some 450 injectors in. I throw the code P1106 which is:
Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
Now...I have my settings set for -25 across the board, I have a gsr. This code isn't thrown all the time. I cant seem to pin point it, it happens randomly...usally about twice a day the code will be thrown...
Thanks
-Dan
Old Oct 20, 2003 | 06:42 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: CEL after VAFC install (citrus3000psi)
Have you swapped in a new MAP sensor? Maybe the old sensor is bad?
Old Oct 20, 2003 | 06:49 PM
Default Re: CEL after VAFC install (Gee3)
I adjusted the fuel trims and roughtly 1 hour later the code showed up...If it is the map sensor its a pretty big coincidence.
Old Oct 21, 2003 | 03:50 PM
Anybody?
superturboprelude
Nov 4, 2004 05:39 PM
gutted
Oct 9, 2004 08:01 PM
ILLICON3000
Aug 4, 2004 03:25 PM
neo1z
Oct 7, 2003 11:01 PM
Mugen Mike
Jun 19, 2003 09:19 AM
