injector recommendation
Old Dec 7, 2011 | 10:06 AM
masonracing's Avatar
Default injector recommendation
here is the new build.
laskey built 85mm bottom end. 11.5.1 compression
skunk2 pro1 valvetrain.
stock TB and intake manifold (rule in my class)
4to1 header
last season i ran stock injectors. more then luckly ill be over 200hp with this setup. what can i get away with for injectors?? thanx
Old Dec 7, 2011 | 10:32 AM
DirtyDA9's Avatar
Default Re: injector recommendation
I would go for something like 330cc's, something around there would be good. What about pump, fpr, and tuning device? What are you using for those?
Old Dec 7, 2011 | 10:52 AM
i run a inline high pressure airtex pump. not sure on lph's. no fpr. its going to be tuned with hondata.
what do i look for when buying injectors? mine r obd2
Old Dec 7, 2011 | 11:03 AM
my pump is 135 lph....basically stock
Old Dec 7, 2011 | 11:06 AM
DirtyDA9's Avatar
Well really it doesn't matter what size you run, because you can always adjust pulse width and duty cycle. So in all honesty you could run 1000cc if you wanted and they will be tuned down to precision. But it's better to go higher cc and tune down, then to go too low and not be able to tune up. So maybe go with DSM 450cc injectors and get a good tune.
Old Dec 7, 2011 | 11:07 AM
DirtyDA9's Avatar
I would go with something like 330-450cc. DSM 450's can be had for $45
good info for me...thank u
Old Dec 7, 2011 | 11:09 AM
mark@silbernage's Avatar
I was looking around recently and read a bunch of posts on Injector Dynamics... here's a good example: http://forums.clubrsx.com/showthread...7#post36562986
They seem to have a good pattern and perform well at idle even with the higher volume versions - you might consider their smaller one (750cc?) as it seems to have more than enough capacity for growth without sacrificing idle/off idle performance.
I know opinions abound, and it's challenging to find objective (measured) ones with all the seat-of-the-pants and truisms out there.
Perhaps someone here has experience with them? I have a similar setup to the one you're describing and that's what I'm leaning towards when the $$ become available.
BTW- I agree with the 330cc -ish sizing if any other injector were being considered; it's about right considering the application.
Food for thot..
Old Dec 7, 2011 | 11:12 AM
DirtyDA9's Avatar
No problem. Good luck with everything.
I forgot to mention that if you do go with DSM 450's, they are high impedence, so you will need to splice in resistors into each injector wire, or get a resistor box from like a 91 integra.
I forget which size resisters you use, there are plenty of write up's on it, and they are only like $5 for all of them from radioshack.
Old Dec 7, 2011 | 02:47 PM
GagnarTheUnruly's Avatar
ID 770s or 1000s
Old Dec 7, 2011 | 03:08 PM
OH_1fstgsr's Avatar
ID 725's
or FIC's Fuel Injector Clinic
or Deatschwerks
All of these injectors use newer technology and have a better spray pattern. Thus making more power.
Old Dec 7, 2011 | 04:10 PM
Zarma's Avatar
Originally Posted by GagnarTheUnruly
ID 770s or 1000s
I would go with 770's thats what I am using for my build. However I am also running E85 so needing a little more.
I remember reading through one of profunctions builds from MikeySpec. He was running 85X89 build, and if I remember right it was with 770's and E85 as well
Here is the link feeling kind of lazy and don't want to read through all the pages.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/profunction-kinsler-present-epic-all-motor-bseries-manifold-testing-2841539/
As long as your tuning and have an an adjustable FPR then more is better.
Old Dec 8, 2011 | 06:30 PM
thanx for the info everyone. liking the looks of the Deatschwerks 550's.
next question. i plan on buying walbro 190. do i really need an adustable fuel regulator? can u please explain/recommend 1.
Old Dec 8, 2011 | 06:38 PM
yungkhmer's Avatar
cheap, DSM 450's,walbro 255 and a blox adjustable fuel pressure regulator and gauge.
Old Dec 8, 2011 | 07:50 PM
DirtyDA9's Avatar
Yes you will need an FPR, I have always used Aeromotive ones on my DSM's, they work great.
Old Dec 9, 2011 | 02:01 AM
OH_1fstgsr's Avatar
I can only assume that the car will be tuned on Hondata, Chrome, Neptune or something. No need for a FPR, stock fuel pressure will work fine.
Replacing the fuel pump isn't a bad idea, some of these parts was way over 10 years old now.
Old Dec 9, 2011 | 09:58 AM
racebum's Avatar
backwards. low impedance injectors use the resistor box to come up for the 94+ cars.
if you could get a set of dsm 450s cheap they would be more than enough. and or if you wanted to kick the resistor box, you could do something like:
http://www.ebay.com/itm/4-380cc-DENS...#ht_1749wt_928
i would not use big big injectors for an NA honda. yes you can tune them but they are way out of the optimum range when you run them at a 35% duty cycle.
using the calc here http://www.fuelinjectorconnection.co...widercalc.html
if you guess 230 crank hp out of that engine with a typical .5 BSFC it puts you at 377cc's at an 80% duty cycle which is just perfect for the denso's in that ebay link
Old Dec 9, 2011 | 01:02 PM
thenoxus1's Avatar
I've heard great things about using the RDX injectors as well. Solid upgrade, good spray pattern etc
Serdar
10
Jul 8, 2015 06:48 PM
Lonewolf1983
37
Jul 9, 2014 01:06 AM
boofunit
Aug 14, 2011 09:28 PM
rickoner
Jun 19, 2009 09:03 AM
servion
Jan 20, 2004 02:16 PM
