car takes a while to start, help?
Old Sep 25, 2002 | 10:52 PM
kingrobby's Avatar
Default car takes a while to start, help?
Here is the deal, 94 Ls with AEM CAI, AEM fuel rail, AEM FPR(set to 45psi), DC header and exhaust, MSD ignition and coil. When I go to start my car(hot or cold, doesnt seem to matter) it turns over for way longer than it used to then it starts. It used to start almost right away, now it takes like 3 or 4 seconds. Everything is pretty up to date maintenance wise(plugs, cap, rotor, fuel filter,oil,etc) except for my O2 sensor. No other problems like lugging or using lots of fuel or anything. Could it just be the volume of the fuel rail taking a while to fill up, as soon as the car shuts off fuel pressure drops to zero. Maybe fuel pump? Any suggestion?
Old Sep 25, 2002 | 10:55 PM
Mase's Avatar
Default Re: car takes a while to start, help? (kingrobby)
turn the ignition to on.....let the fuel pump prime, then start it, see if that helps.
Old Sep 25, 2002 | 10:58 PM
kingrobby's Avatar
Default Re: car takes a while to start, help? (CDooMe2)
I tried that once or twice, didnt seem to do anything.
Old Sep 25, 2002 | 11:13 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
i believe that is usuaully when you are low on gas
[Modified by CiRcUiTsi, 8:14 AM 9/26/2002]
Old Sep 26, 2002 | 05:43 AM
TimoneX's Avatar
New User
Your fuel pressure should stay up for some time after shut down. How's your milage? I'd look for sources of fuel pressure leaks.
Old Sep 26, 2002 | 10:25 AM
kingrobby's Avatar
Default Re: car takes a while to start, help? (TimoneX)
its got about 110,000 miles on it and I have looked for fuel leaks but dont seem to find any.
Old Sep 26, 2002 | 10:28 AM
EL Vap133's Avatar
When was the last time you changed your battery?
Old Sep 26, 2002 | 03:51 PM
InTeGrA B18b1's Avatar
fuel injector cleaner helped my car start in 1 click but when i put my racing fuel in it got clogged
Old Sep 26, 2002 | 06:21 PM
Aaron M's Avatar
Default Re: car takes a while to start, help? (LsRTuRBo)
my 2001 gsr has that problem when i have less than a 1/4 tank of gas. takes a few sec to start, sometimes its embarrassing when other people are around like at school
spore691
Nov 3, 2012 08:44 AM
bengal
Aug 9, 2006 08:50 AM
EGNA
Jul 12, 2006 03:31 PM
civic89si666
Jan 31, 2006 05:22 PM
Magick211
Oct 30, 2004 10:28 PM
