Car Stalls with A/C on.
Old 06-26-2007, 04:41 PM
DVPTeG's Avatar
Default Car Stalls with A/C on.
I have a pretty basic stock 2000 Gs-R with I/H/E and Skunk2 Intake Manifold.
Lately it's been stalling when I have the A/C on. It'll stall and then it's REALLY hard to start back up. When the a/c isn't on it idles around 700-800RPM. With the A/C it drops to about 250RPM and then just dies.
Adjusted the idle on TB and it's still doing the same thing.
I live in Florida and I can't drive around ALL summer with no a/c!!
Please help with any suggestions on what might be the culprit!
Thanks,
Heather
Old 06-26-2007, 06:24 PM
bshshondaman06's Avatar
maybe the idle air control valve isnt doing its job? but i dont know why it would be hard to start. any CELs?
Old 06-26-2007, 08:51 PM
ProJectCvic's Avatar
Default Re: (bshshondaman06)
Another possible cause is the voltage regulator in you alternator....get it check out for free.
Old 06-27-2007, 12:42 AM
sPaRk'iT's Avatar
Default Re: Car Stalls with A/C on. (DVPTeG)
Man, my buddy accord is doing the same thing he called me today to go see it, any more ideas what might cause this??
Old 06-27-2007, 11:30 AM
DVPTeG's Avatar
No cel's. Gonna clean the iacv and see if that helps.
Old 06-28-2007, 07:43 AM
nutsack's Avatar
vacuum leak on the skunk 2 intake manifold?
Old 06-28-2007, 10:12 AM
mr_gs-r's Avatar
Default Re: (*******)
my idle drops but no stall, have been troubleshooting it but havent found a definite answer yet.
Old 06-29-2007, 10:50 AM
DVPTeG's Avatar
Default Re: (mr_gs-r)
Still have the problem after everything. Not as bad since I cleaned the IACV. If I ever figure out what is causing this stupid problem I'll post....
Old 06-29-2007, 11:26 AM
kartman5's Avatar
Default Re: (DVPTeG)
My son has the same problem, but he is running a built LS with crower 404's. He
simply turns the A/C off while at idle and turns it back on when driving. Even with
a dyno we were not able to make it work at idle. Good luck!
00_Em1_
05-08-2016 06:30 PM
sd_ej1
10-14-2008 06:26 PM
Tytank7
05-08-2008 11:29 AM
JDMkidGSR
11-09-2006 05:26 PM
DIYMIKE
11-14-2004 06:03 PM
Quick Reply: Car Stalls with A/C on.
