Car shakes at 40mph +
Old 01-24-2005, 06:51 AM
black sohc civic's Avatar
Default Car shakes at 40mph +
My car shakes violenty from 40mph and up. The whole car and steering wheel shakes? Anyone know the cause? I was told it was a bad axle? Didnt hear any clicking noises when turning, at low speeds the car is fine. Any help is appreciated...
Old 01-24-2005, 06:56 AM
qcktegls's Avatar
Default Re: Car shakes at 40mph + (black sohc civic)
check your alignment. but a bad axle could be the cause
Old 01-24-2005, 07:00 AM
LsVtec98's Avatar
did you curb check you car really hard also? could have bent your rim/rims.
Old 01-24-2005, 09:39 AM
cnydc2's Avatar
Default Re: (LsVtec98)
Maybe your wheels are really out of balance? Or your tie rod ends could be worn? ANy noises?
Old 01-24-2005, 09:46 AM
9hatch2's Avatar
it dould be a bad axle, the axle does not have to make a clicking noise when you turn to be bad. check your tires and alingement
Old 01-24-2005, 10:05 AM
b18vtek's Avatar
Do you feel a shake at low speeds to? It could be the alignment, bad bushings, bent rim and last and least axle. But it is most likely your alignment, if you feel the shaking after a certain amount of speed.
Old 01-24-2005, 01:29 PM
gsrteg97's Avatar
my daily is a 94 4 door civic and mine did that about 60 ... what i did was jack up the car and start it and let it slowly go into gear and get out and look at the axles ... mine were real bad looked like an egg rolling on a table on both sides
Old 01-24-2005, 02:24 PM
calxtreme's Avatar
sounds like axles or simple problem with alignment. Also check your tire balance.
Old 01-24-2005, 02:27 PM
hockey_Fan59's Avatar
is it snowing where you live? snow might be lodged in the wheel causing it to be off balence. otherwise, i'd bring it to a shop that does balencing.
kaiba
11-04-2006 11:14 AM
LudeJdm
06-02-2005 11:50 PM
kmf0211
09-17-2004 12:45 PM
oldDude
03-07-2004 02:41 PM
d_mina
11-27-2003 12:09 PM
Quick Reply: Car shakes at 40mph +
