Car overheating
Old May 11, 2005 | 12:59 PM
njandrewg's Avatar
Default Car overheating
For some reason when I'm in traffic or even at a drive thru my car's temperature goes towards the 75% mark. But when I'm actually driving...even for a minute, it goes down to less than 25% mark. I have a intake, which i think makes the difference. How much coolant should I have?
Old May 11, 2005 | 01:29 PM
db8R's Avatar
check your thermostat or on the housing cover of the thermostat theres a ECT switch that tells the fan to come on...
Old May 11, 2005 | 01:35 PM
njandrewg's Avatar
Default Re: (DB8GSR)
where is that
Old May 11, 2005 | 01:37 PM
db8R's Avatar
follow ur lower radiator hose to it! that should take you to this thermostat housing that the hose is clamped onto.. its bolted on by two 10mm and the switch will be rite on the housing.
Old May 11, 2005 | 01:39 PM
db8R's Avatar
search is key if you still dont understand buddy!
Old May 11, 2005 | 01:57 PM
NeoGSR's Avatar
20 bucks sayin it's the thermostat
Old May 11, 2005 | 02:04 PM
yrethguad's Avatar
Default Re: Car overheating (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">How much coolant should I have?</TD></TR></TABLE>
As much as will fit. heheh. The reservoir will siphon it in, so if it's empty you need to add. It's marked on the reservoir where to fill to. When cool, open the rad cap, you should see coolant, or if not give the upper rad hose a little squeeze and you should see it. Fill accordingly. Sounds like a fan prob though, if it's only under low or no speeds. It's an easy fix.
Old May 11, 2005 | 02:06 PM
yrethguad's Avatar
Default Re: (NeoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">20 bucks sayin it's the thermostat </TD></TR></TABLE>
Yeah could be not opening enuf, but still doesn't accound for temp drop after moving. The fan(s) should maintain.
slipstreamxk1's Avatar
it might be the thermostat but check your coolant levels, if the resevoir looks almost empty thats atleast part if not the whole problem. top it off and see how it runs.
Old May 11, 2005 | 04:15 PM
NeoGSR's Avatar
Default Re: (yrethguad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yrethguad &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah could be not opening enuf, but still doesn't accound for temp drop after moving. The fan(s) should maintain.</TD></TR></TABLE>
well, if it's stuck at a certain point, when you start to drive and move air, it will drop, sometimes even too much.....exact thing happened to me this winter
Rein4st
Apr 7, 2012 11:17 AM
Akai Star
Apr 14, 2010 05:29 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
Civicracer17
Jun 23, 2006 03:50 AM
BoostNEF
May 14, 2005 01:18 AM
