cant read cel!!!! HELP!
Old Mar 17, 2008 | 12:42 PM
ls19integra95's Avatar
Default cant read cel!!!! HELP!
ok, so my cel came on so i tried jumping it, as soon as i do the cel goes off and doesnt blink and as soon as i take the wire out of the connector the cel comes right back on. so i took it over to a shop and had them hook it up and they said the machine cant connect to my car to read the code... whats wrong? could this be caused by my Hondata S300???
Old Mar 17, 2008 | 02:45 PM
Default Re: cant read cel!!!! HELP! (ls19integra95)
bump...
Old Mar 17, 2008 | 02:48 PM
all-mtr-teg's Avatar
Is your car an OBD2 and you converted to OBD1, if so, then yeah, I don't think you can pull the code with your Hondata.
Old Mar 17, 2008 | 03:04 PM
HmgLauj69's Avatar
i had the same thing happen to me, what's weird is that when i tried a different ecu to check if it's some kind of electrical problem, there wasn't, and switched back to my regular ecu the cel stayed on like it's suppose to.
i have a s100; i heard you can read your cel from a s200/s300 in a different way
Old Mar 17, 2008 | 04:25 PM
Default Re: cant read cel!!!! HELP! (HmgLauj69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Is your car an OBD2 and you converted to OBD1, if so, then yeah, I don't think you can pull the code with your Hondata.</TD></TR></TABLE>
no, my cars OBD1, its a 95 integra ls...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same thing happen to me, what's weird is that when i tried a different ecu to check if it's some kind of electrical problem, there wasn't, and switched back to my regular ecu the cel stayed on like it's suppose to.
i have a s100; i heard you can read your cel from a s200/s300 in a different way </TD></TR></TABLE>
yes, with the s300 i have a software that i can put onto a lap top and use to pull/erase codes from my ecu but the problem is that my lap tops broken ... but as soon as i get it back im going to try and use that to pull the code, but in the mean time id like to try and figure out why the hell i cant pull the code now.
Old Mar 18, 2008 | 04:54 PM
up...
Old Mar 19, 2008 | 01:13 PM
ok, so i figured out what was tripping my check engine light, my number 2 cylinder spark plug was going bad and was misfiring now and then, BUT i still havent figured out why the hell i cant connect to the ecu to read the codes...
95BG33PGSR
Dec 28, 2011 08:35 AM
Zaraki
Mar 31, 2008 08:26 PM
HmgLauj69
Dec 6, 2007 09:50 AM
TORQUE MONSTER
Jul 25, 2007 05:26 AM
Soled Out
Jan 26, 2003 05:47 AM
