Camber problem or alignment?
Old Feb 16, 2005 | 12:23 PM
DCTODAR's Avatar
Default Camber problem or alignment?
One of my wheels on the passender front side sticks out to the right a little bit but I think it effects my ride, the steering wheel pulls to the right when I'm going through rough rodes.
When I straighten out the steering wheel and look at my car, the passenger front wheel looks like it is turned a little bit to the right.
I don't believe this is a camber because the contact patch is contacting the road, will an alignment fix this problem?
I think what caused it was that I was riding with different size tires for awhile, 205/55/15 and 205/50/15, I want to correct this problem, any ideas will be great.
Old Feb 16, 2005 | 12:27 PM
timmy8151's Avatar
Default Re: Camber problem or alignment? (DCTODAR)
First thing you should do is get your car aligned. See what your readings are and then proceed from there.
95integraLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCTODAR &raquo;</TD></TR><TR><TD CLASS="quote">
I was riding with different size tires for awhile, 205/55/15 and 205/50/15 </TD></TR></TABLE>
Old Feb 16, 2005 | 01:34 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
either your toe's out of spec, or something's bent in your suspension. get a toe alignment and have them check everything out as far as suspension and steering goes.
Old Feb 16, 2005 | 02:24 PM
DCTODAR's Avatar
Default Re: (MugenDude)
Thanks for the feedback,
I'm gonna get it aligned this weekend
Old Feb 16, 2005 | 02:54 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">either your toe's out of spec, or something's bent in your suspension.</TD></TR></TABLE>
sounds like toe to me most likely.
lud_08
Suspension & Brakes
Oct 12, 2010 04:44 AM
EG6R
Aug 13, 2007 06:09 AM
dafuzzbudd
22
Feb 20, 2007 11:17 AM
acuraLSSE95
Sep 25, 2004 04:35 PM
drvfast
Mar 17, 2003 02:21 PM
