Camber Kits?
I just installed a set of H&R Sport springs with KYB-AGX shocks on my 95 Integra GS-R. Question I have for any of you who might have experience with it is whether or not I need camber kits? I took my car to get aligned and the guys at the shop are telling me I have a 1-2degree negative camber on my front tires. Is this a serious problem and do I need to get the kits?
You want a little bit of negative camber for cornering but as long you are in factory specs of camber then you should be fine. I can't remember the factor specs but I lower my car with the eibach prokit and the Koni yellows to add an extra 1" drop. If you do decide to use a camber kit make sure that you get an alignment becasue you will be toed in.
I have H&R sports on my G2 teg and my alignment wasn't that far from factory specs either but i decided to go get the ingalls kit anyway, so at least my left and right have the same camber specs. Right now am set at -.5 for both front wheels.
[Modified by jonsteR, 11:13 PM 9/26/2001]
