camber kit
Old Jun 2, 2008 | 06:16 PM
jrob0107's Avatar
Default camber kit
i lowered my car and now im looking for a camber kit.it is a 94 integra.i dont want that inside tire wear so i need some help finding one and picking one out.this should be easy for some of yall seeming that most of yall have probably dont this before.what have you guys found out?
Old Jun 2, 2008 | 08:38 PM
BlueIntegraBoy's Avatar
Default Re: camber kit (jrob0107)
Skunk2 Pro Series
Old Jun 2, 2008 | 08:44 PM
94lsrhd's Avatar
skunk2, ksport, ingalls all make kits. and depending on how low you are you may need a toe kit in the rear. and also for the front the best is the pillow ball instead of the arms so that you can adjust it with more accuracy. And also the inside tire wear is from toe and not camber. bad camber will show on the tread with a slope across it. where bad toe causes the inside tire wear.
Old Jun 2, 2008 | 10:05 PM
Spody02's Avatar
Default Re: camber kit (94lsrhd)
i have one for sell
http://www.hondamarketplace.co...08532
Old Jun 3, 2008 | 08:34 AM
Lazychynksta's Avatar
SKUNK2 pro-series ALL THE WAY. They use the good materials, good warrenty, good fender clearence not like most other front camber kits.
Fo-Do Fanatic
20
Feb 10, 2011 01:34 PM
CoastalSi
17
Dec 30, 2009 06:38 PM
spens 91 Ef
32
Apr 23, 2009 12:39 AM
GsrSedan
Apr 6, 2002 08:15 PM
eTec
Mar 14, 2002 03:55 PM
