Cable to Hydro Trans in a DA???
Old May 10, 2006 | 06:30 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Cable to Hydro Trans in a DA???
I've got a 91 Intergra RS w/ a jdm Si-R b16a w/ a cable trans. Well the trannys starting to go and I have access to a working b18c1 GS-R trans, alas the question. What will I need to put a Hyrdo trans in? I looked on Hasports site but it doesn't look like its been updated in years....
Can I still use the cable trans' clutch and flywheel as well? help!!!
Old May 10, 2006 | 06:59 PM
SuzukaBlueAP2's Avatar
Default Re: Cable to Hydro Trans in a DA??? (ComeOnKip)
Cable and Hydro trannies and their parts are not interchangeable.
Old May 10, 2006 | 07:00 PM
ComeOnKip's Avatar
anybody? to the top
Old May 10, 2006 | 07:01 PM
ComeOnKip's Avatar
sooo theres no way i can put a hyrdo tranny on a oem cable equipped motor?
Old May 10, 2006 | 07:07 PM
Default Re: (ComeOnKip)
You'd have to get all the lines, master cylinder, slave cylinder and clutch and pressure plate for the hydro tranny. I'm pretty sure there are different mounts also...and I'm not 100% certain about the shift linkage.
Sorry for the unknowns there...
That's a lot of effort though.
Old May 10, 2006 | 07:08 PM
BlueIntegraBoy's Avatar
My friend bought a Hasport cable to hydro kit. He's running a hydro GSR in his EF.
Old May 10, 2006 | 07:14 PM
ComeOnKip's Avatar
blueintegraboy, did your boy have to replace the entire hyrdraulic system or what?
Old May 10, 2006 | 08:58 PM
MJobe's Avatar
the kit comes with a lever that your clutch cable connects to wich in forth moves the shift fork on the hydro tranny
Old May 10, 2006 | 09:20 PM
whoa its len 2's Avatar
Default Re: Cable to Hydro Trans in a DA??? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Cable and Hydro trannies and their parts are not interchangeable.</TD></TR></TABLE>
ys1 trannys can adapt hydro internals. may require some minor grinding down of the inner case of the ys1. 92+ clutch all the same.
Innovative has a cable to hydro kit. Your clutch cable pulls a lever which actuates the shift fork.
innovativemounts.com
Old May 10, 2006 | 09:25 PM
Slo Integ's Avatar
Default Re: Cable to Hydro Trans in a DA??? (whoa its len 2)
Look into innovativemounts.com, like the above said.
cool stuff. I never had any need for that, and I didn't even know it existed.
Old Jun 24, 2006 | 04:56 PM
ComeOnKip's Avatar
i've heard things that this makes the clutch incredibly heavy, anybody have one that they've driven??
Old Jun 24, 2006 | 07:00 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
This is hasport's adapter kit so u can use a hydro tranny with a cable, this is not my car, its just a pic i found
Old Jun 25, 2006 | 02:20 AM
riceball777's Avatar
Default Re: (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">You'd have to get all the lines, master cylinder, slave cylinder and clutch and pressure plate for the hydro tranny. I'm pretty sure there are different mounts also...and I'm not 100% certain about the shift linkage.
That's a lot of effort though.</TD></TR></TABLE>
incorrect
all b seris pressure plates and flywheels are interchangable
that are 2 different clutch disk. 90-91 small spline and 92-01 big spline. so a 92-93 ys1 cable trannie clutch will work fine in a hydro trannie. piolet bearings are the same. there is a cable throw out bearing and a hydro thro out bearing
Old Jun 25, 2006 | 11:03 AM
TheCheeseWedge's Avatar
the shift linkage is different between hydro and cable the U part that connects to the bottom of the shifter is wider on the hydro
John The G
Transmission & Drivetrain
Mar 8, 2023 06:49 PM
Jdmek920
Jan 22, 2013 09:53 PM
RyanA
Jan 30, 2007 07:19 AM
robbin
Apr 14, 2004 12:42 PM
rice a roni
Dec 6, 2003 04:12 PM
