a/c question
Old Apr 2, 2010 | 07:03 AM
jimmy o.'s Avatar
Default a/c question
I have a 91 integra LS i want my a/c to either blow a tad colder or harder i belive everything is factory the car is still r12 too it does get cold just takes a lil while to cool off
what do u think i need to do here i want it ice cold it gets hot in texas and i have black paint and interior lol
Old Apr 2, 2010 | 09:43 AM
JCurry's Avatar
Default Re: a/c question
put a set of gauges on it and see if its still fully charged
Old Apr 2, 2010 | 12:03 PM
AcuraLsSE's Avatar
There isn't a lot you can do after its fully charged. Having too much or too little will cause it to not blow as cold. AC systems have a direct pressure to temperature ratio. When its really hot outside its not going to blow really cold. Whatever you do DON'T go buy a can that says ice cold with stop leak.
Old Apr 4, 2010 | 11:11 AM
jimmy o.'s Avatar
i got one can of r12 i dont know if any shops around here mess with r12 systems anymore...
Old Apr 4, 2010 | 02:34 PM
AcuraLsSE's Avatar
In school we still had an R12 system. Most people convert because of the cost of R12 though.
Old Apr 15, 2010 | 09:12 PM
ShreqBoi's Avatar
how can i convert the a/c system on my da/db from r12 to r134??
Old Apr 16, 2010 | 09:53 AM
TheAsian's Avatar
The way you convert r12 to r134 is just changing the valve core. I would strongly suggest taking it somewhere to get this done, because the pressures in a a.c system are pretty exact. But one thing you could do to help improve your system is to replace the filter once your system is evacuated. A clean filter and will allow the freon to flow better and more efficiently. Main reason I say take it somewhere is because the system will be checked for leaks under vacuum.
Old Apr 16, 2010 | 10:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Not only checked for leaks, but also the correct type and amount of oil put into the system.
I had to have my A/C discharged/recharged awhile back so that I could replace my heater core, and I paid a shop $160 to do it. $80 to have them discharge the system and pull a vacuum on it, then another $80 a few days later to recharge it back using the readings they got when discharging it.
97akwerd
Sep 14, 2005 08:06 PM
Spectrum24x
Sep 2, 2005 09:54 AM
BoostedAcura
Sep 10, 2002 07:20 PM
