A/c compressor not turning on
I have a 96 integra ls that was auto with a b18c5 full swap and a hondata s300 and rywire budget tuck harness. My a/c compressor is not turning on when i press the ac button. I checked fuses and relays and they are good. I checked the wires and it seems like instead of getting ground the switch wire was getting a positive signal. I dont know what to do
Re: A/c compressor not turning on
If never turn on, then
1. low refrigerant - tried to press the AC valve for 0.1s to see whether it spray out refrigerant
2. If compressor run for few seconds, then stop, then the radiator fan is not running, and leads to compressor not running. Checks radiator fan motor or coolant temp sensor
hmtcrxsir
22
07-25-2008 03:19 PM
superfuji57
07-14-2007 05:38 PM
