a/c blowin fuse
Re: a/c blowin fuse (danteisme)
Condenser FAN. The condenser itself isn't an electrical component.
Get out your DMM. Sometimes you can't see the short. Sometimes its a fan motor going bad that just draws too much current. Visual inspection of the wires only works if you're lucky.
Re: a/c blowin fuse (JimBlake)
when a fuse blow everytime u change it
it means that one of the wires that goes to the thing is that is not working, is broken or damage , so get a voltimeter and look the wires
try to find the wire that is damege, if you have replace something on your car recently star looking from there you might damage a wire without knowing .
and if you din't find the short there is another way but it will take u more time to fix it here it goes:
place a bigger fuse like is the one is blow is 10a replace with a 30a
the fuse will not blow but the wire that is damage will burn the plastic
that way you know which wire is damage ,(the one that burns the plastic) and take the fuse off as soon as you star seen some white smoke coming from the wires .
thats the dumb way to fix it i did it like the second option and had to take all my interior out to replace the burn wire from my tail light to the fuse box .
my problem was that i replace one of my tail lights and when i tie the bolts i screw the wire with the bolt by mistake . so keep the wires away from torn down with bolts . i hope this help u
latino honda
05-24-2019 11:32 AM
