Bright Clear Corner
Old Nov 14, 2001 | 11:58 AM
ITSFEROZ's Avatar
New User
Default Bright Clear Corner
I have a 97 integra and was wondering if any of you guys expierenced any melting on your clear corners when you reverse the wires, so that you have a a very bright light almost as a headlight. does the reflector inside start to melt or what. cause that is what i am expierencing. please let me know if i did anything wrong or could do something to better it.
thans
Old Nov 14, 2001 | 12:03 PM
gsxr's Avatar
Default Re: Bright Clear Corner (ITSFEROZ)
this is interesting, i've never heard of it...i'd like to know too
Old Nov 14, 2001 | 12:26 PM
Mr. Thunderlips's Avatar
is this on your stock corner lights, or aftermarket clear ones...ive heard of the aftermarket ones melting but not the stock ones, i did this on my stock 99 amber lights, and theyve held up fine...
Old Nov 14, 2001 | 12:31 PM
ACURACY_VTEC's Avatar
New User
Default Re: Bright Clear Corner (Slo_Teg)
how do u make Corner lights Bright?
Old Nov 14, 2001 | 12:32 PM
neo1z's Avatar
whoa...how do you reverse the wires???!!!?!?!
explain please i like knowledge (and bright lights)
Old Nov 14, 2001 | 12:45 PM
New User
Default Re: Bright Clear Corner (neo1z)
anyone?
Old Nov 14, 2001 | 01:04 PM
Cramerox's Avatar
Default Re: Bright Clear Corner (sweet-teg)
There are three wires on the harnest. Red Green and black. you switch the wires that are on the outside wich are green and black i believe.You dont need to cut the wires just pop them out of the harnest with a tack or something thin.( i will double check about the wires) this gives you a brighter signal light. The only draw back is, that when you signal, the fronts do not blink. so be carefull because if you are making a left turn yelding to on comming traffic they may not know if your going straight or turning left. Not to safe.
Also you will notice that you will have hyper blink automatically. The rear tail lights will blink BTW.
I have done this on after market clears and so for no problems.
Old Nov 14, 2001 | 01:34 PM
mr2's Avatar
mr2
Default Re: Bright Clear Corner (Cramerox)
just switch it back, not worth melting the housing
Old Nov 14, 2001 | 01:40 PM
ITSFEROZ's Avatar
New User
well i did these on an aftermarket clear corner and it melting the housing inside because it got soo hot. but i have seen them on other people's car and wondered if they're ever melted or what
Old Nov 14, 2001 | 01:44 PM
Cramerox's Avatar
I switched my back...hahah i was tired of getting honked at in San Francisco
carbonn
Lighting
Jul 26, 2009 07:35 PM
DC5mike
Nov 21, 2007 08:09 PM
accordmaniac23
Feb 10, 2007 05:05 PM
JasonBlackEJ1
Nov 22, 2002 08:11 PM
ridiculous
Oct 23, 2002 09:51 PM
