Brakes. Problem.
Old Jul 2, 2006 | 01:09 AM
Groove_D's Avatar
Default Brakes. Problem.
91 DA.
When i apply brakes, car pulls left and right. At faster speeds the stronger the pull.
What do you guys think can cause this?
I checked pins on the calipers. They are perfect, not seized at all. I checked all the bushings/control arms and they are fine as well.
The only thing is that brake pads have a very slight angle wear.
I'm running out of ideas on what it can be. It gets really annoying to drive it as well.
Could a wrong set toe cause this?
Any info would be apreciated.
Thanks.
Old Jul 2, 2006 | 01:17 AM
sujinX's Avatar
you might want to check the alignment. it could also be the pads. but u said it pulls both ways.. so iuno about that. usually wen it pulls to a side wen you apply the brake, the brake fluid is not evenly distributed.
Old Jul 2, 2006 | 08:32 AM
Groove_D's Avatar
Default Re: (sujinX)
So i should just try bleeding the system then. Maybe there are air pockets?
Old Jul 2, 2006 | 08:43 AM
jdm_bones's Avatar
Default Re: (Groove_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Groove_D &raquo;</TD></TR><TR><TD CLASS="quote">So i should just try bleeding the system then. Maybe there are air pockets?</TD></TR></TABLE>
^^^ yup, start the bleeding from the passenger rear, to driver rear, to passenger front, and then driver front...New fulid would be nice!
Old Jul 2, 2006 | 01:37 PM
Adambomb's Avatar
Hmm, i'm having the same problem with my dc2. Even after getting the car re-aligned, I always pull left.
Old Jul 2, 2006 | 11:20 PM
Groove_D's Avatar
Default Re: (AdamO)
Is that bleeding procedure necessary? Can't i just bleed 2 front?
Old Jul 3, 2006 | 01:49 PM
Groove_D's Avatar
I tried bleeding it but not with a vacuum bleeder. I just bled it manually through the bleeder screws. It didn't help man. Maybe vacuum bleeding is more efficient.
Old Jul 3, 2006 | 02:54 PM
JokerTypeR's Avatar
Have you lowered the car lately?
Check your tie rods, while you're at it. Check your wheel bearings too.
Old Jul 5, 2006 | 09:28 AM
Groove_D's Avatar
Default Re: (JokerTypeR)
My car has been lowered for awhile. I changed the tie rods about 4 months ago. I'll double check it.
But today i bled it one more time following the helms sequence. It helped on the low speeds. Up to 40 mph. Anything higher the car pulls.
Someone please help. Sick of this by now.
Old Jul 5, 2006 | 04:43 PM
nightrider81's Avatar
Default Re: Brakes. Problem. (Groove_D)
i was having the same problem. it was the alignment. and check your hub and bearings. Also after you go for a good drive stop and put your hand near each rim. feel for the rim thats the hottest. If one rim is giving off alot of heat then its the caliper. The caliper could be locking up because mine was.
Old Jul 5, 2006 | 09:10 PM
Groove_D's Avatar
Default Re: Brakes. Problem. (nightrider81)
So was it the allignment or was it the calipers man? Allignment shouldn't be involved here i'm thinking, since when you drive without braking the car goes straight.
Old Jul 5, 2006 | 09:12 PM
__oversea's Avatar
sound like un-even wear of rotors or pad.
Old Jul 6, 2006 | 12:07 PM
JokerTypeR's Avatar
The pull may be there even when you're going and you just don't feel it...when you brake, it might be more pronounced. But if it's only under braking, check your calipers and as stated by God ( ) check your rotors. Make sure they're bled.
Old Jul 6, 2006 | 04:02 PM
it was the caliper. did you put ur hands near each rims to see which 1 is the hottest?
Old Jul 6, 2006 | 09:23 PM
Groove_D's Avatar
Ok today i finally got my hands on it. I took everything apart. Rear bottom pins in the calipers had a major seizure. Plus front piston was seized as well. I made it more or less free with the C clamp pushing it in and then mounting it back and pumping the brakes. I did this about 5 times. How do i keep it from being stuck again? Anybody knows?
Also, i cleaned up the rear pins but i had no tool to check if the rear pistons were seized. Will buy that tomorrow and double check. It made a big difference, car doesn't pull under 40 mph anymore yet it still pulls on highway speeds??
And the wheels are hot even. Both front ones are about the same temp but the rears are much colder though.
Old Jul 8, 2006 | 03:15 PM
keep them greases up thats all i did
Old Jul 9, 2006 | 12:39 AM
Groove_D's Avatar
I think you have no idea what i'm talking about it.
Old Jul 9, 2006 | 05:53 AM
GSRNetics's Avatar
Sounds like you might want to buy new calipers. A little pricy, but considering the safety factor, you can't put a price on something saving your life if it comes down to it.
lPat
Jun 3, 2007 07:51 PM
Bizarre
Feb 5, 2005 04:42 PM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
MidNiteMysT
Jun 30, 2003 10:24 PM
SIMATIC
Apr 25, 2003 10:07 PM
