Brake problem
Old Jan 25, 2002 | 01:26 PM
Newbie In A Teg's Avatar
Default Brake problem
After I start up the engine and let it warm up for 3-4 minutes, the first 4-7 times I apply the brakes it makes some sort of scratching, grinding noise.. but only the first few times. After a little while it goes away.
Anybody know what that means? Do I need more brake fluid or something? How can I tell?
Old Jan 25, 2002 | 01:59 PM
Rainmaker's Avatar
Default Re: Brake problem (Newbie In A Teg)
pads, rotors: aftermarket or stock? If you are using semi-metallic pads, a little scraping noise when cold is often normal. Also, could it have anything to do with where you park? Specifically, is there any sand in the wind that might settle on your rotors and may take a few grabs to wipe completely off?
HTH, Rainmaker.
Old Jan 25, 2002 | 02:27 PM
Default Re: Brake problem (Rainmaker)
No, no sand or anything like that..
The car is a 96 Integra se. I have no idea if the pads/rotors are stock. Any easy way to tell?
[Modified by Newbie In A Teg, 11:27 PM 1/25/2002]
k_lude
Oct 4, 2006 09:39 PM
lo0nY
11
Feb 20, 2005 10:57 PM
RSVTECDC4
Aug 4, 2003 10:21 PM
functionFiRst
Oct 2, 2002 09:49 PM
