help...brakes are screaming...
Old Oct 2, 2002 | 08:36 PM
functionFiRst's Avatar
Default help...brakes are screaming...
alright i just changed my brakes a few weeks back...everything is perfect...a couple days ago i noticed that my front left brake seems to be making a quick chiping noise, not loud but kinda annoying.
My front left side screeches when i press down on the brake slightly. i checked the brake fluid and it's fine.i used brake cleaner to clean the calipers.anyone else know what else could it be?
Old Oct 2, 2002 | 08:43 PM
Mikey's Avatar
Default Re: help...brakes are screaming... (MikeRotch)
Changed your brakes meaning... PADS or ROTORS? If you only changed the rotors, you may have worn the pad enough down to reach the indicator. Take off your rim and take a looksie at your pads.
If you changed your pads and your rotors, you must further your research. I've seen rocks get lodged between rotors and pads... just showing it can be anything really. Your best option is take a looksie!
Old Oct 2, 2002 | 09:00 PM
Default Re: help...brakes are screaming... (Mikey)
i changed the pads...everything seems to look fine...
Old Oct 2, 2002 | 09:49 PM
Kamin's Avatar
did you grease the back of the pads when you installed them?
Sic_DA_Nine
Dec 2, 2006 06:46 AM
turnsignalandy
Nov 12, 2006 03:35 AM
old_school_dohcvtec
Apr 30, 2005 07:47 AM
faSHOwidIT
Apr 18, 2005 02:06 AM
ophdehEEzY
Mar 8, 2003 07:06 PM
