Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Honda Accord Brake Guides
- Honda Accord: Why is My Brake Light On?
Guide to diagnose trouble and recommended solutions
Brake Lights not lighting up??
#26
Re: Brake Lights not lighting up??
sameee issue man , anyone have diagram for rsx brake pedal switch? and is this my last option befor i got out and get this thiing the bulb is good not one fuse is out grounding problems .. baha new car smell so no. jp but reall talk i need the info stat the rsx is my daily for work.....
#27
If your 3rd brake light is working, it's not the brake switch or a fuse. The bulbs need replaced. I repaired hail damage on a vehicle that came back today with this issue. Even though the lights came on when turning on the lights, they were not working when braking. These bulbs have 2 parts to them, unlike the other bulbs for reverse and the blinker, and 1 part of them can go bad with the other working.
#28
bumping cause I have the same issue, but for me its just the passenger side that won't work...BUT ONLY when you turn the lights on.
update: for anyone who comes across this, try swapping your tail lights out ALONG with the harness mounted in the housing it's self.
#29
bump ..same issue i had, brake lights working but when i turn on my headlights they dont work. I found the problem..if your fuses and brake switch were good, check the brake bulbs! they can go both ways, it has to notches. if install the wrong way thats the problem. try the other way and it worked for me. hope that helps..
#30
On my 02 rsx when i hit the brakes when i have my lights on during the night on one bulb in each taillight is getting brighter but they are all lit at night. side question does oneyone have aftermarket halo headlights and if so how did they set them up to run all the time ?
#31
( I did crash into a fence on my right passenger front side. Pretty hard. So if that could be a issue... )
#32
Hey did you find a solution I hit my right side too had to replace some things please help.
Hey I have the issue where my brake lights do not turn on when I turn my headlights on. But they do light up when I brake. So my running lights are out.... and my horn is out.. so should I do same process, check the fuses etc. Bolds the brake switch?..
#33
Another thing to check would be to make sure your brake switch is being touched by the white pad thing on the pedal. sometimes those break.
https://dz310nzuyimx0.cloudfront.net...dfe6e356c4.gif
see number 22
see number 22
#34
not sure what else to do other than trace wiring. Changed and switched bulbs they were good. Changed and switched fuses they were also good cleaned all contacts with a die grinder and electrical cleaner and still only works when running lights off , very dimly, doesn’t work when running lights are on only third brake light. Changed out brake light switch all new bulbs and fuses l, guess the only thing left to do is trace wires unless someone has an actual answer other than these steps along with testing circuits…
#35
Ragged91ZC
11
03-12-2004 01:01 PM
