Bosch o2 sensors
Bosch o2 sensors
Well, I need a new o2 sensor. I was wondering if I need to buy the OEM one. I heard that you can get Bosch o2 sensors and they will work properly. I was told that they cost like $40 at autozone. Do these work just as good as the OEM ones? Right now im getting a CEL code and I'm quite sure its from my o2 sensor, I just don't want to have the same problem with my new one. I'm also getting very bad gas milage.
Oh, and I have a OBD I 94 GSR if it matters.
Re: Bosch o2 sensors (ILOVEGIRLS)
This is totally off the topic but ILOVEGIRLS I am trying to send you a message but I don't seem to be able to, maybe b/c I don't post here enough. Anyway I was wondering if you still have some side skirts for tegs (oem optionals). Let me know.
Sorry to post jack your thread MikelH
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Re: Bosch o2 sensors (MikelH)
I bought one and spliced the OEM end onto the Bosch sensor. I was getting a "bad cat" code before I hydrolocked the GSR, now I'm getting a "running rich" code on my R engine. I don't know if it's my Carsound Cat or the sensor. I need to borrow someones good o2 sensor to see if that's the problem. I don't want to spend more $$ if I don't have to.
These guys sell OEM sensors but depending on which o2 sensor it is, it can be more expensive than the Bosch: http://oxygensensors.com/
Modified by Gee3 at 9:21 PM 9/8/2003
Re: Bosch o2 sensors (Gee3)
I just put in a brand new Bosch primary o2 sensor and know I am getting a o2 sensor heater code. Not sure whats wrong, gonna check the wiring in it one of these days. Never had the code before the new sensor though.
Re: Bosch o2 sensors (VTEC-DA)
I've never had a problem with these sensors. If you know how to do any electrical wiring, you'll have no problem doing this. The sensor works fine as a replacement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikelH »</TD></TR><TR><TD CLASS="quote">Well, I need a new o2 sensor. I was wondering if I need to buy the OEM one. I heard that you can get Bosch o2 sensors and they will work properly. I was told that they cost like $40 at autozone. Do these work just as good as the OEM ones? Right now im getting a CEL code and I'm quite sure its from my o2 sensor, I just don't want to have the same problem with my new one. I'm also getting very bad gas milage.
Oh, and I have a OBD I 94 GSR if it matters.</TD></TR></TABLE>
I just replaced my O2 Sensor with a Acura one. Cost more but I think its worth it. I came across a problem though while changing it. My old O2 was siezed into the header so I ended up having to replace it also. Something so minor ended up costing me a small fortune.
schweiger
10-23-2012 05:38 PM
98IntegraLSNonVtec
08-04-2006 09:18 PM
rviray
12
10-31-2004 04:27 AM
spencedogg
13
10-28-2003 06:45 PM
