best shift points for maximum acceleration?
Old Mar 28, 2004 | 07:34 PM
hott-nix's Avatar
Default best shift points for maximum acceleration?
i've gota 97 gsr
assuming the clutch isn't slipping and you are already at a slow roll in first gear.
wheres the best place to shift in each gear, to get maximum acceleration?
i did some testing tonight, but i think i'm getting too high in the rpm range to get good responce.
anybody have some tips?
(btw, did a search and came up short)
Old Mar 28, 2004 | 07:39 PM
Grandmasta's Avatar
I'm usually shifting at 7800.. whether or not that's best... *shrug*
PowerHouse's Avatar
Default Re: best shift points for maximum acceleration? (hott-nix)
i tend to shift 200 rpms before redline. i notice the pull is harder and the front jumps up a bit higher after each shift.
Old Mar 28, 2004 | 07:44 PM
97pearlwhitegsr_canada's Avatar
yea i am not sure eaither.. each car is different, best bet would be go to dyno
Old Mar 28, 2004 | 07:47 PM
mskibbz-T's Avatar
Default Re: best shift points for maximum acceleration? (97pearlwhitegsr_canada)
You have to plot out your shift points on a dyno graph by doing runs in each gear, then you can calculate the best shifting point in order to fall into your powerband in the next gear
Old Mar 28, 2004 | 07:51 PM
DC2*Integra's Avatar
Default Re: best shift points for maximum acceleration? (mskibbz-T)
i go all the way to 8100
Old Mar 28, 2004 | 08:09 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: best shift points for maximum acceleration? (DC2*Integra)
Go till fuel cutoff!!!
Well that is what I did to run my 14.9
Old Mar 28, 2004 | 08:16 PM
penney's Avatar
Default Re: best shift points for maximum acceleration? (arizsun21)
i shift at or a little past redline, it feels like it's fastest that way, but it might not be...i wish i could get on the dyno to figure it out
Old Mar 28, 2004 | 11:07 PM
xplanetearth420x's Avatar
Default Re: best shift points for maximum acceleration? (97vtecGSR)
i shift at 8400 ran a 14.989
Old Mar 29, 2004 | 12:15 AM
G1 TEGGY's Avatar
Default Re: best shift points for maximum acceleration? (xplanetearth420x)
If you can't plot it out on a dyno chart, just at or slightly above redline.
Old Mar 29, 2004 | 01:29 PM
hott-nix's Avatar
i might try a few more runs tonight.
i was shifting at just a hair under 8K. maybe i'll try higher
Old Mar 29, 2004 | 01:44 PM
nolexforever's Avatar
<--- 8100-8200 rpm shifts.
Old Mar 29, 2004 | 03:13 PM
stumpyf4's Avatar
Default Re: (hott-nix)
Try to keep the secondary intake butterflies open when you shift. Means the engine speed doesn't drop below 5700-5800rpm, practice make perfect. It's harder to do in first since the engine speed climbs so fast, 2nd to 3rd is easier.
Old Mar 29, 2004 | 03:32 PM
tachyteg's Avatar
Default Re: (stumpyf4)
8400 14.9 @ 95 with a bad 2.44 60ft...
Old Mar 29, 2004 | 03:43 PM
Elemental's Avatar
[hijack]
sorry
when in the rpm range does it become bad for your engine?
[/hijack]
Old Mar 29, 2004 | 03:53 PM
integraGSR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizsun21 &raquo;</TD></TR><TR><TD CLASS="quote">Go till fuel cutoff!!!
Well that is what I did to run my 14.9</TD></TR></TABLE>
but if you actually hit the fuel cutoff, your times will be slower.
want to maximize acceleration? well, shift at the poin to where the next gear is in your power range. so in a GSR, if you shift right at redline, the next gear will usually put you back at the vtec engangment. if you shift at a lower rpm, it will take you some time for you to hit vtec again and will make you lose precious time when racing.
Old Mar 29, 2004 | 04:47 PM
jdmbsol21's Avatar
Default Re: best shift points for maximum acceleration? (integraGSR1)
redlining seems to give me the best result....ill eventually take it to the track to get a time
Old Mar 29, 2004 | 05:41 PM
luvinmyGSR's Avatar
Default Re: best shift points for maximum acceleration? (g2witrotas)
8100 / 8200
Old Mar 29, 2004 | 06:57 PM
turbotommy's Avatar
Default Re: best shift points for maximum acceleration? (luvinmyGSR)
&lt;----- 10200!
Old Mar 29, 2004 | 07:31 PM
slooogsr's Avatar
when i ran at the track (my only time so far) i shifted 7900-8000, felt good....... ran a 15.1 @ 95.9 w/ 2.6 60ft (bogged, didnt know how to launch).
EG-SIXV-TEC
32
Apr 5, 2010 06:03 AM
lude98SH
Jun 15, 2008 09:40 PM
drewwatts23
Jun 14, 2004 11:41 AM
REDMAN1322
Nov 7, 2001 06:00 AM
