best low end torque
Old 06-18-2006, 01:13 AM
dc2long's Avatar
Default best low end torque
hi
i was wondering what is the best way to get low end torque with a budget of 250. i drive a 96 gsr with only an aem v2 intake.
what kind of headers/exhaust?
any input would be helpful
thanks
Old 06-18-2006, 01:25 AM
watsvtecEK's Avatar
Default Re: best low end torque (LongsGSR87)
stock gives best low end torque.
Old 06-18-2006, 01:28 AM
VHOA's Avatar
Default Re: best low end torque (D 2da A9)
buy a "supercharge any car" mod
Old 06-18-2006, 02:13 AM
Night Owl
Leo C's Avatar
Default Re: best low end torque (VHOA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VHOA &raquo;</TD></TR><TR><TD CLASS="quote">buy a "supercharge any car" mod</TD></TR></TABLE>
do you ever post anything hepful or technical?
as far as low-end torque, a short ram as well as 4-2-1 headers should make some power down low. a twin-loop exhaust will also free up some low-end ponies.
Old 06-18-2006, 02:17 AM
tomlinson619's Avatar
Default Re: best low end torque (shutupnskate)
only $250 to spend??? dang.. dont expect to feel a NOTICEABLE difference with that much $$.. u can buy a used 4-2-1 header or put in a couple more hundreds and get ctr cams
Old 06-18-2006, 05:20 AM
SoEvoL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LongsGSR87 &raquo;</TD></TR><TR><TD CLASS="quote">hi
thanks</TD></TR></TABLE>
save more money, that kind of budget isnt going to buy something that will even put a major dent on the trq chart.
Old 06-18-2006, 05:43 AM
kliebertfamily's Avatar
Everything you post is useless. Why don't you post something that will help him instead?? If you don't know what you are talking about don't post. Like I do.
Philip
Old 06-18-2006, 05:45 AM
Default Re: best low end torque (SoEvoL)
Exactly what SoEvol said. Save your money because it will be hard to buy something for 250 that will have any noticable hp and torque gains.
Philip
Old 06-18-2006, 01:48 PM
dc2long's Avatar
Default Re: best low end torque (kliebertfamily)
thanks for your inputs
i was planning on buying dc sport headers 4-2-1 because i heard that was for low end and 4-1-1 is top end. those go for about $250. then after i was thinking about getting a greddy exhaust.
but i also heard that 4-2-1 sucks from someone on HT
after i get my headers and exhaust ill save up for some cams. itr or skunk s1 ?
Old 06-18-2006, 03:11 PM
-Championship-'s Avatar
why get 4-2-1?..yeah low end torque but gsr's are high revving engine and vtec starts at 4400, so you need as much torque for high end..get 4-1 header, better top end....and for cams go for ctr intake and itr exhaust...
Old 06-18-2006, 03:44 PM
cm zak's Avatar
go buy an ls block and do ls vtec ;x
Old 06-18-2006, 03:52 PM
Snafubmx234's Avatar
Default Re: (cm zak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">go buy an ls block and do ls vtec ;x</TD></TR></TABLE>
Once again, save the money, or use it on something that would make your car a lot more fun to drive (short shifter, weighted ****, etc)
Modified by Snafubmx234 at 5:41 PM 6/18/2006
Old 06-18-2006, 04:11 PM
for what?..he already has a gsr...gsr has potential...ok anyway i dont want to get into this....just go get some money GOD DAMN IT...you cant do anything without that green paper
Old 06-18-2006, 06:19 PM
psychotic_z's Avatar
Default Re: (project_B18C1)
You can do this for free:
Advance your timing to the maximum recommend spec. It was 18 degrees BTDC on my 92 DA, but you can check your own with a repair manual. I think it might have it with the idle information on one of the stickers under your hood also.
You can do this with a timing light - just loosen the bolts on your distributor and rotate the distributor clockwise or counterclockwise to alter the timing. Use the timing light for reference. I forget which way is which... And do NOT advance/retard past the recommended specs.
May or may not make any difference at all... but it falls within your budget
Old 06-18-2006, 07:20 PM
9311dan's Avatar
save money and buy a smsp header and a r*sr exhaust and you'll be great.
Old 06-18-2006, 07:52 PM
Ricer no 7's Avatar
Default Re: (9311dan)
not to be rude but smsp header and rsr exhuast are real expensive for some guy saying he wants to spend 250 hehe
cut out your resonator box and put a kn filter on. The resonator box is all the tubing and crap under the intake box and goes below then wraps back up to your engine. Its a free mod so it fits your budget
Old 06-18-2006, 09:54 PM
Night Owl
Leo C's Avatar
Default Re: (psychotic_z)
Advancing your timing will net some power gains, but at the cost of your engine running rich. Do this at your own risk
Old 06-18-2006, 11:22 PM
VTECcnIT's Avatar
why? so he can throw more $$$ down the drain?
Old 06-18-2006, 11:35 PM
CompanyFlow's Avatar
Default Re: best low end torque (project_B18C1)
The cars powerband calls for more low end to get the car into vtec and really moving. No ***** 'til that 4400 buddy.
Old 06-18-2006, 11:38 PM
jdm_bones's Avatar
Start by getting a job! Your going to need more than 250 bones..
Old 06-18-2006, 11:41 PM
Nevets's Avatar
Default Re: best low end torque (jdm_bones)
Up the compression.
Old 06-19-2006, 06:16 AM
rkrone's Avatar
do a basic tune up, new spark plugs, oil filter, fuel filter, ect...
i got some used dc 4-2-1 (e-mail me)
then go buy some suspension with the money you saved!!
Old 06-19-2006, 08:08 AM
1337whp's Avatar
Default Re: best low end torque (rkrone)
[QUOTE=rkrone]do a basic tune up, new spark plugs, oil filter, fuel filter, ect...
QUOTE]
lol just make your head gasket thinner to get a little more compression, advance timing, maybe weight reduction, goodtires will help you gain traction for the low end. perhaps hone in your driving skills to help your launches. theres many many things. get a job though ~250 is nothing when it comes to the aftermarket
Old 06-19-2006, 08:22 PM
9311dan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
not to be rude but smsp header and rsr exhuast are real expensive for some guy saying he wants to spend 250 hehe</TD></TR></TABLE>
i know. what's he expect for $250? get a job and save.
Old 06-20-2006, 12:14 AM
Its still hard to save any good amount when you have been at a job for less than a few years, especially as a student. But I guess at that point you should be concentrating on school anyways.
Quick Reply: best low end torque
