backfiring jumping idle
Old Feb 10, 2018 | 07:31 PM
delisle's Avatar
Default backfiring jumping idle
i got a 1988 integra R.P.M go all over the place backfired so bad it blew a hole through the muffler spark plugs build up carbon real quick idle jumps sporadically car well get up to speed if you shift early otherwise jerks you around in high RPM spark plugs are new and wires and rotor cap +fuel filter fuel PSI is 32psi at idle
Old Feb 10, 2018 | 08:55 PM
acmoc's Avatar
Default Re: backfiring jumping idle
Check your ignition timing. There should be a label under your hood. Also check mechanical timing and your vacuum lines.
Look for a vacuum leak around your throttle body/intake manifold.
Also, is your check engine light on?
And the fuel psi should be measured with the vacuum lines disconnected.
Old Feb 11, 2018 | 07:58 AM
jlicrx's Avatar
sounds to me like you have the spark plug wires in the wrong locations on the distributor cap - the D16A1 is not like other D-series engines - the wires go: #1 at top, #3 closest to radiator, #4 at bottom and #2 closest to firewall
Old Feb 12, 2018 | 09:28 AM
delisle's Avatar
Spark plugs are correct backfire drill heavy drove it home felt like it was driving really good for a second now it won't start at all
Old Feb 12, 2018 | 09:30 AM
delisle's Avatar
Vacuum lines are good so I unplug all vacuum lines to test fuel pressure
reureubear
Nov 22, 2015 03:34 PM
95_DB7
Aug 31, 2012 09:56 PM
fourdoorteg
Jan 25, 2010 05:09 PM
thecruzs2007@yahoo.com
Sep 22, 2009 07:41 PM
92eg6lsvtec
Sep 19, 2004 08:19 PM
