B18C1/C5
Old Nov 14, 2003 | 11:43 AM
SLOAZZ95's Avatar
Default B18C1/C5
WHAT IS THE DIFFERENCE BETWEEN THESE 2 MOTORS
Old Nov 14, 2003 | 11:58 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: B18C1/C5 (SLOAZZ94)
Turn your Caps Lock off (click here).
Old Nov 14, 2003 | 12:32 PM
Passaudi1.8t's Avatar
New User
Default Re: B18C1/C5 (integra707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 &raquo;</TD></TR><TR><TD CLASS="quote">Turn your Caps Lock off (click here).</TD></TR></TABLE>
LOL
I'll be nice this time.... in a nutshell, the blocks are virtually the same, but the internals are stronger in the C5. Balanced and polished crank, stronger/lighter rods, coated pistons, etc set it apart from the GSR's components. The heads are what really set the two apart. The C5's head uses a single runner IM, where the GSR's is dual runner and has the secondaries that open @ 5800. The C5's has a mild port job, larger T/B, and won't bolt up to the GSR head. The C5's head also has a factory port job, lightweight valves, stiffer valvesprings, and more powerful cams. Think of the C5 as a built GSR motor using all Honda factory parts.
Old Nov 14, 2003 | 03:00 PM
CNSK's Avatar
Default Re: B18C1/C5 (Dr.FeelgooDC2)
be nice...
Old Nov 14, 2003 | 07:00 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOAZZ94 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT IS THE DIFFERENCE BETWEEN THESE 2 MOTORS
lol
Old Nov 15, 2003 | 12:46 AM
:jdmshmaydm:'s Avatar
Default Re: B18C1/C5 (integraL)
Despite popular rumors and myths, there is no difference. They only have a different name to differentiate which one goes in an ITR and GS-R.
Old Nov 15, 2003 | 09:04 AM
riceball777's Avatar
lol
damn talk about newbs
Old Nov 15, 2003 | 10:50 AM
Bubb Rubb's Avatar
</TD></TR></TABLE>ABOUT 20 HORSEPOWER, YOU CAN SQUEEZE OUT 25 IF YOU LEAVE THE CAPS LOCK ON
Old Nov 17, 2003 | 04:38 AM
SLOAZZ95's Avatar
Default Re: B18C1/C5 (Bubb Rubb)
See this is why noone wants to post here and goes to all the other honda forums, because when a simple question is asked the all u fu***** as****** got to add some queer comment just to get your post total up. if u arn't answering the simple ???? then dont fu***** type on my post!!!!!!
Old Nov 17, 2003 | 04:44 AM
JDM_Honda_Fiend's Avatar
Default Re: B18C1/C5 (Gatecrasher19AF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher19AF &raquo;</TD></TR><TR><TD CLASS="quote">Despite popular rumors and myths, there is no difference. They only have a different name to differentiate which one goes in an ITR and GS-R.</TD></TR></TABLE>
Ermm.. I smell false information.
This is a good explanation:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr.FeelgooDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL
I'll be nice this time.... in a nutshell, the blocks are virtually the same, but the internals are stronger in the C5. Balanced and polished crank, stronger/lighter rods, coated pistons, etc set it apart from the GSR's components. The heads are what really set the two apart. The C5's head uses a single runner IM, where the GSR's is dual runner and has the secondaries that open @ 5800. The C5's has a mild port job, larger T/B, and won't bolt up to the GSR head. The C5's head also has a factory port job, lightweight valves, stiffer valvesprings, and more powerful cams. Think of the C5 as a built GSR motor using all Honda factory parts. </TD></TR></TABLE>
Cheers
b18c5EF9
Aug 13, 2006 12:24 PM
mathTHUG
Jul 13, 2005 10:15 PM
Andre
Dec 30, 2004 04:32 PM
sleepin91teg
Dec 14, 2003 12:54 PM
Lo-Buck EF
Mar 2, 2003 11:50 AM
