B18c help needed.
Old Mar 14, 2006 | 06:09 PM
nosamo's Avatar
Default B18c help needed.
i'm getting a check engine light, and the coding is giving me number 17
not quite sure , but please analyse.
check light lit up for a lil (10) then flashed 7 times, hence 17.
what is the coding for that?
is it knock sensor? because my vtech not coming in, so i assume knock sensor not workin, thus no vtech?
i know the VAFC would bypass the knocksensor and vtech would work, but is the problem the knock sensor, or if not, what is?
Old Mar 14, 2006 | 08:16 PM
Dutch-VTEC's Avatar
Default Re: B18c help needed. (nosamo)
This guy is hilarious, mad me laugh so hard. This will be a good one with lots of flaming.
Old Mar 14, 2006 | 08:35 PM
ITR#132's Avatar
17 is vehicle speed sensor circuit.
Old Mar 14, 2006 | 11:31 PM
SiR Adam's Avatar
maybe you should get a new vtech
Old Mar 14, 2006 | 11:39 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: B18c help needed. (SiR Adam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Adam &raquo;</TD></TR><TR><TD CLASS="quote">maybe you should get a new vtech
Old Mar 15, 2006 | 12:27 AM
95TegSE's Avatar
Default Re: B18c help needed. (SlammedDC2)
The VAFC also does not bypass the knock sensor, it does bypass the vtec oil pressure sensor's signal to the ecu however.
Old Mar 15, 2006 | 05:05 AM
djstain's Avatar
had the same prob wid mine, check your VSS carfully, and the connector 2 for corosion,...is your speedometer working?
Old Mar 15, 2006 | 05:21 AM
tystikgsr's Avatar
Default Re: B18c help needed. (djstain)
yeh I'm having the same type of issue with my gsr, but mine makes some grinding noises upward of 6000 rpms. any ideas i'm kinda new to v-tech.
Old Mar 15, 2006 | 06:07 AM
crapanese's Avatar
hahahah. this thread is funny.
Old Mar 15, 2006 | 06:24 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (crappyDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tystikgsr &raquo;</TD></TR><TR><TD CLASS="quote">yeh I'm having the same type of issue with my gsr, but mine makes some grinding noises upward of 6000 rpms. any ideas i'm kinda new to v-tech.</TD></TR></TABLE>
Damn people learn to spell it's vtec, vtech is a phone. WTF
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crappyDC4 &raquo;</TD></TR><TR><TD CLASS="quote">hahahah. this thread is funny. </TD></TR></TABLE>
indeed
if your speedometer is working then clear out your ecu and the CEL will shut off
Modified by JDMdc2lsVtec at 9:04 AM 3/15/2006
95BoostedEJ1
10
Nov 23, 2007 10:51 AM
.BigSexy
Aug 6, 2006 03:09 PM
nosamo
Mar 15, 2006 08:03 AM
ebrakeracin4
Nov 25, 2004 09:19 AM
