B18C Engine Noise
Old Oct 22, 2013 | 03:48 PM
rcurry14's Avatar
Default B18C Engine Noise
My GSR started making this noise last night and it got louder after driving it today. It is louder depending on the load and comes and goes at idle. It is there while accelerating or decelerating. It is there if I'm coasting in gear and cut the engine off so It's not related to the ignition or fuel system it seems to be something mechanical. My guess right now is the water pump bearings or the tensioner for the timing belt. The crank pulley has a pretty good wobble at idle that disappears once the rpms go up but I don't know if that is related. I also thought it may be the crank bearings making noise if the pulley is wobbling. I recorded the noise here if you all have any ideas: Integra engine noise - YouTube
Thanks,
Ryan Curry
Old Oct 23, 2013 | 06:22 AM
rcurry14's Avatar
Default Re: B18C Engine Noise
Sorry this is the link:
http://www.youtube.com/watch?v=SMk1K...ature=youtu.be
Old Oct 23, 2013 | 01:21 PM
rcurry14's Avatar
turned out to be an exhaust leak on the header close to the engine in between the primaries where you couldn't see it.
Old Oct 29, 2013 | 10:20 AM
jdmsleeper12's Avatar
That's great to hear
Old Oct 29, 2013 | 04:55 PM
B_Swapped93's Avatar
would still check valve lash....sounds too metallic to be just an exhaust leak
whatmeow
Honda Civic (2006 - 2015)
Nov 28, 2018 03:31 PM
CristianAccord
Jun 12, 2018 08:51 AM
Zumo
Feb 16, 2007 10:45 PM
jdmlife
May 31, 2004 03:08 PM
ramz7887
May 12, 2003 03:58 PM
