B18B1 beef up
Whats up everyone. Here is the scoop. I have a 1997 Integra LS with the B18B1. I was trying to figure out what to do to it. I was thinking about maybe doing a cam upgrade, maybe Crower Stage 2s, but then I get lost on everything else. Anyone want to try and help me out with what else to do? Do I need a chipped ECU, injectors? I just get myself lost every time I look at stuff.
I know people that have done LS-T setups, but i'm not trying to just spin tires into 3rd gear, just more low end. Any help would be cool. Thanks
the cams will give u mostly high end power but will definately give u power. youll need to upgrade your valvetrain though if u go with stages 2 cams. you could get a phearable ecu with a basemap or something simillar. and you should probobally get a tune.
Get a tune when youre done adding stuff, if you get an ECU tune and add something, it was all for nothing, but yes upgrade your valvetrain like billcass said, at more aggressive cam profiles, you're bound to get some valve float... Good luck!
jordan_civic
Aug 7, 2007 10:31 AM
