b18a1 b18b1 distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">Nope...one is OBD1 and the other OBD2</TD></TR></TABLE>
it actually depends, if he has a 92-93 b18a1 and needs a dizzy he could use one from a 94-95 b18b1 without a single modification, both are obd1.
those are the only 2 that are compatible between the 2 motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">as long as it bolts to the engine , they are all the same , just have to repin/rewire them. </TD></TR></TABLE>
just because it bolts to the engine doesnt mean its the same, if you have to re wire it to work its DIFFERANT.
ALL NON VTEC B SERIES DIZZY'S WILL BOLT TO ANY OF THE NON VTEC B HEADS, BUT ALL DIFFER BETWEEN OBD PER THE HARNESS.
i did the b swap my problem is that i hook up the right dizzy with sensor doesnt even work but when i put old one back in it starts and runns good but still throwing up codes 16 and 9 its eritarting
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
