b18a1 b18b1 distributor
i have the b18a1 engine, i need a ditsributor, and i foubnd one for a b18b1 engine...are the distributors interchangable?
Re: b18a1 b18b1 distributor (hondaguy69)
bump
Nope, even the 90-91 and 92-93 are different. Don't go by the motor. Go by which OBD it is. What year is your motor?
Re: b18a1 b18b1 distributor (2ndgentegracer)
you can rewire them though , i think whats hes asking is will they actually bolt onto the engine. all the dizzys have the same sensors in them.
Nope...one is OBD1 and the other OBD2
Re: b18a1 b18b1 distributor (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">Nope...one is OBD1 and the other OBD2</TD></TR></TABLE>
it actually depends, if he has a 92-93 b18a1 and needs a dizzy he could use one from a 94-95 b18b1 without a single modification, both are obd1. those are the only 2 that are compatible between the 2 motors. |
Re: b18a1 b18b1 distributor (schardbody)
as long as it bolts to the engine , they are all the same , just have to repin/rewire them.
Re: b18a1 b18b1 distributor (blackKready)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">as long as it bolts to the engine , they are all the same , just have to repin/rewire them. </TD></TR></TABLE>
just because it bolts to the engine doesnt mean its the same, if you have to re wire it to work its DIFFERANT. ALL NON VTEC B SERIES DIZZY'S WILL BOLT TO ANY OF THE NON VTEC B HEADS, BUT ALL DIFFER BETWEEN OBD PER THE HARNESS. |
i understand this , lol.
i did the b swap my problem is that i hook up the right dizzy with sensor doesnt even work but when i put old one back in it starts and runns good but still throwing up codes 16 and 9 its eritarting
