b18a and b18b block?
Old Jul 30, 2003 | 11:12 AM
Ransom's Avatar
Default b18a and b18b block?
ok i have tried to look up this question but a lot of people just go around it. what is the difference between the two block? do they have different sensors? do you have to change your ecu if you put a b18b in a non 0bd car? and will a cable tranny bolt to a b18b block? could you help me out!!
Old Jul 30, 2003 | 12:11 PM
blueintegra90's Avatar
Default Re: b18a and b18b block? (LudeSH)
i know that a b18b u can bolt a cable tranny to. but i dont know on the other question
Old Jul 30, 2003 | 02:33 PM
lol at u's Avatar
I have a 97 B20B in my 90 integra. I used the non-obd harness and ecu. Also all B series trannys mount up to any b series block except for b20a but make sure you have the right clutch disk with the right tranny.
Old Jul 30, 2003 | 04:13 PM
TEXN3's Avatar
Default Re: (b20 DA9)
blocks the same...its a b-series. the head, intake manifold and a few other things are different. i don't think obd0 and obd1 will be that much of a problem. the b18b started in 92, the b18a was from (in the US) 90-91.
Old Jul 30, 2003 | 04:31 PM
Ransom's Avatar
thanks for the info.
Old Jul 31, 2003 | 05:45 AM
arw321's Avatar
Default Re: (texnteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texnteg &raquo;</TD></TR><TR><TD CLASS="quote">blocks the same...its a b-series. the head, intake manifold and a few other things are different. i don't think obd0 and obd1 will be that much of a problem. the b18b started in 92, the b18a was from (in the US) 90-91.</TD></TR></TABLE>
Just to clarify, all 90-93 non vtec integras came with the b18a1. 92-93 did NOT come with the b18b.
Adam
Old Jul 31, 2003 | 05:08 PM
TEXN3's Avatar
Default Re: (arw321)
are you sure about that? 92 was when the motor had 140hp and was carried over into the g3...which had a slight bump in power about 5 years later.
1990-1991 Acura Integra
Courtesy the 1991 OFFICIAL ACURA Sales Brochure
ENGINE AND ELECTRICAL
Engine Type 1.8 L, DOHC, 4-cylinder, 16-valve
Engine Block Aluminum alloy with cast-iron cylinder liners
Horsepower, SAE net 130 hp @ 6000 rpm
Torque, SAE net 121 lbs.-ft. (16.8 kg-m) @ 5000 rpm
Induction System Programmed Fuel Injection (PGM-FI)
1992-1993 Acura Integra
Courtesy the 1993 OFFICIAL ACURA INTEGRA Sales Brochure
ENGINEERING RS-LS-GS
Engine Type 1.8L, DOHC, 4-cyl.
HP, SAE net 140 hp @ 6300 rpm
Torque 126 lbs-ft (17.4 kg-m) @ 5000 rpm
Redline 6500 rpm
Displacement 111.9 cu in (1834 cc)
Compression Ratio 9.2 : 1
i have been under the impression for many years that the 92 teg was equipped with a b18b...and integras that were non-vtec were so equipped from then on... if you can prove me wrong, i will stand corrected.
Old Jul 31, 2003 | 05:34 PM
90teg's Avatar
yeah even though 92-93 came with 140hp vise the 130hp from 90-91 they are both still b18a
Old Jul 31, 2003 | 08:27 PM
vladd's Avatar
Default Re: (90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg &raquo;</TD></TR><TR><TD CLASS="quote">yeah even though 92-93 came with 140hp vise the 130hp from 90-91 they are both still b18a</TD></TR></TABLE>
correct
Old Jul 31, 2003 | 11:42 PM
thaiphob's Avatar
Nikon!!!
Default Re: (90teg)
for sure dude!
hgw84
Mar 7, 2006 03:03 PM
Tammy_EP3
Oct 16, 2003 02:12 PM
THE BEAST
Jan 10, 2003 10:03 AM
racecarpete
Nov 24, 2002 04:10 PM
InfamousRS
Sep 5, 2001 08:33 AM
