b17a1 help
Old Dec 19, 2006 | 08:37 PM
Holderb20's Avatar
Default b17a1 help
I have a 93 gs-r and im looking to get some power out of it but it has 200,000 on it should I rebeld it and put high comp pistons in it or just do a few bolt on's? im looking to put down about 150-200 whp... or just boost the **** out of it with rods and pistons
Old Dec 19, 2006 | 08:43 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: b17a1 help (Holderb20)
I would just rebuild it and make a decently powered NA motor. boost complicates things a lot and if you're only trying to make 200 HP then just make it NA
Old Dec 19, 2006 | 08:52 PM
95 integra's Avatar
Default Re: b17a1 help (god.loves.ugly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by god.loves.ugly &raquo;</TD></TR><TR><TD CLASS="quote">I would just rebuild it and make a decently powered NA motor. boost complicates things a lot and if you're only trying to make 200 HP then just make it NA </TD></TR></TABLE>
200whp NA can be a little harder then it sounds. That and 150-200 is a huge range. If the motor still runs well/has good compression, then I wouldnt worry with rebuilding it. Maybe put in some new bearings, but thats all I'd do. Bolt ons should get you close to the 150 mark, so just rock out with that.
Old Dec 20, 2006 | 10:33 AM
Sam92Teg's Avatar
Default Re: b17a1 help (95 integra)
GSR, that's 150 whp stock. Guess you met your goal. Do a compression check to see the overall condition and go from there.
Old Dec 20, 2006 | 11:37 AM
95 integra's Avatar
Default Re: b17a1 help (Sam92Teg)
Given the B17 is stronger then its rated power (just off what I've seen) but its really around 135ish whp stock....which bolt-ons should put you just over the 150 mark.
Old Dec 20, 2006 | 05:53 PM
ctc801's Avatar
REBUILD but resleeve the block for better pistons!
Old Dec 22, 2006 | 02:46 PM
Holderb20's Avatar
Default Re: b17a1 help (ctc801)
well the motor runs fine but has a slight hesitation almost like a turboed car! I would like to see 150 or 170 whp it has 136.3 whp stock without the intake. I would like about 170 whp. I have a intake, header what all would i need without going internal.
simonEp3
Aug 21, 2007 05:05 AM
98jdmek
May 6, 2007 12:27 AM
Wayne_Curr
Oct 21, 2005 03:41 AM
Avenged7x
May 18, 2005 07:15 AM
hahaitzsteven
Jan 9, 2005 06:09 PM
