B17 bore/boost question
ok so i picked up a low mile b17 to build and go into my 92gsr
im going boost so i didnt wanna have it bored if at all possible
long story short #2 has a spun bearing and it marred up the top of the cylinder a little, not too bad, but bad enough to have it bored.
ok my goal is 17-20 psi....
now this is where yall come in
what would yall recommend, get it bored or get it re sleeved????
i didnt really wanna have it re sleeved because of the cost... i could get it done but it is going to set me back pretty good...
thanks in advance
thanks in advance
i did build a 4g63t that put down 287whp
but im unfamiliar with honda sleeve abilities as far as boost goes
dont be an ***, im just asking opinions
boring will be ok. when you do it sience you are going to be getting new pistons get some low comp ones by a good brand. je aris there are a bunch do some reasherch to find the ones that suit you best. while its apart I would get a set of manley turbo tuff rods. sleeving is also a good option but do you have 800-1200+ at doing it. if so I personaly would get darton 84mm sleves put in. but good luck with it all.
Go to the Forced Induction forum for this type of post. There is a great FAQ at the top of the page...that should be the first thing you look at before posting anything. It answers a lot of the beginner questions you may have. Good luck
