b16 compression test should read...?
Old Jan 10, 2010 | 07:14 PM
ryanangelo212's Avatar
Icon2 b16 compression test should read...?
looking to buy a 90 teg with a stock b16 out of a 99 si...
its not running at the moment, but i want to make sure its not blown so i plan to check the compression.
how many psi should it read?
i figure somewhere from 150-200 but id like to get a more exact number.
NOT looking for compression ratio//
Old Jan 10, 2010 | 07:56 PM
cwd14's Avatar
Default Re: b16 compression test should read...?
Standard……………………………….............................. ........187 psi
Minimum………………………………............................... .....135 psi
Maximum variation between cylinders………………………..28 psi
http://www.ej8squad.com/thread-9312.html
Old Jan 10, 2010 | 08:10 PM
Import_spoon's Avatar
My all stock JDM B16 did a 200psi all aross the cylinders.
Old Jan 10, 2010 | 08:48 PM
GagnarTheUnruly's Avatar
Consistency is more important. You want the lowest cylinder to be no less than 85% or 90% of the highest cylinder, although only a couple psi difference is best. Values between 150-250 could probably be considered normal if the consistency is high.
Old Jan 12, 2010 | 05:09 PM
DC2fab's Avatar
i would say around 200 psi for a strong running motor.. i had 225 on every cylinder in my boosted jdm b18c. but as long as none are under 140-150 your good
Old Jul 23, 2012 | 03:05 PM
Markb16a's Avatar
wow my honda is at 100 psi across the board. Oil on my spark plugs on # 2 and # 3. Can anyone tell me the best pistons to get? Probably going to boost it this fall/winter.
Old Jul 25, 2012 | 07:02 PM
Mr91DA's Avatar
it depends on how you do the compression test. if o rings have expanded and the engine was recently running the o rings should have expanded howerver if the engine is cold like in your case number might be lower considering the o rings have not expanded since the engine has not been running long enough for the rings to fully expand.
airslammedcivic2
Apr 8, 2010 12:18 AM
flaxx0r
Oct 14, 2008 10:31 PM
^jefs0ng
Dec 2, 2003 03:28 PM
lothian110
Oct 28, 2003 09:24 PM
lothian110
