axle trouble
Old Sep 21, 2008 | 03:27 PM
hardvtec90's Avatar
Default axle trouble
I'm having troubles getting the driver side axle removed. It feels locked in. Is there a special way or tool to get it out, or does it just pop out?
Old Sep 21, 2008 | 03:33 PM
1992blueGSR's Avatar
Default Re: axle trouble (hardvtec90)
there is no special tool you need, have you disconected your upper A arm and everything, it makes it alot eaisier, if it still doesnt come out, hit the extension housing bracket with a hammer twards the outside of the car so it will pull the axle out, but dont hit the bearings
Old Sep 21, 2008 | 05:00 PM
hardvtec90's Avatar
Default Re: axle trouble (1992blueGSR)
we've been hitting it for like an hour, and it won't seperate.
will heat help remove it or will it [freak] **** up?
Old Sep 21, 2008 | 06:51 PM
BoSox46GSr's Avatar
I've never tried heating it up. But just twist, pull, whack it with a hammer, it will come out.
Old Sep 21, 2008 | 07:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I take a large flat-head screwdriver and place it on the inner CV joint cup, near the intermediate shaft carrier bearing. Then I whack the screwdriver handle with a hammer. Several hits usually get the snap ring on the int. shaft out of the groove in the joint cup.
Why they couldn't make it as simple as forcing a screwdriver between the bearing and the joint cup (like what you do on the passenger side) is beyond me.
Old Sep 21, 2008 | 07:51 PM
hardvtec90's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I take a large flat-head screwdriver and place it on the inner CV joint cup, near the intermediate shaft carrier bearing. Then I whack the screwdriver handle with a hammer. Several hits usually get the snap ring on the int. shaft out of the groove in the joint cup. </TD></TR></TABLE>
Tried that, and it did help a little.. We just ended up clamping on a pipe wrench, and kicked that bitch out.
ill fast
Dec 5, 2008 06:14 AM
sony224422
Oct 2, 2006 09:23 PM
Chris F
Jun 2, 2006 11:21 PM
07734
Dec 1, 2004 06:51 PM
chipper
Jun 8, 2002 07:41 PM
