automatic to standard conversion: help with wiring
Old Jan 19, 2010 | 11:34 AM
  #26
beamer's Avatar
Default Re: automatic to standard conversion: help with wiring
thanx bro anybody else got pix of the wires..?
Old Jan 19, 2010 | 11:20 PM
  #27
96Dc2 GSR's Avatar
did this swap in 2 days..
tell me what your working with and ill tell you what to get and what to doo..
what swap whats it going in etc...go into detail..
Old Jan 20, 2010 | 02:01 AM
  #28
beamer's Avatar
going to swap a gsr motor in my ls shell.
need help with parking brake
need help with reverse lights
need help with clutch pedal connector
i would like to see pix of where the wires are that i need to mess with...
do i need that innovative auto/manual mount?
i have to gsr blocks obd1 and 2 does it matter?
obd2 gsr tranny
obd2 gsr harness
obd2 gsr ecu
Old Jan 20, 2010 | 05:45 AM
  #29
EpHatchy's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
the wiring in these should be the same
Old Jan 20, 2010 | 05:54 AM
  #30
EpHatchy's Avatar
basically the clutch connector wires have to be wired to the 2 fat black wires on the 14 pin connector in the shifter area.the reverse lights have to be wired from the switch on the transmission to 14 pin plug also which are the yellow and green wires..dont forget to remove that shifter interlock or else it wont give you back your key. just unplug it under the dash and remove the white cap and piston from the ignition key housing
Old Jan 21, 2010 | 12:19 AM
  #31
beamer's Avatar
dam thanx alot that helped badass!
siboi04
Nov 14, 2007 04:01 PM
Demonis
Sep 27, 2007 09:08 AM
hmtcrxsir
Mar 25, 2006 08:05 PM
ludesrv
Nov 15, 2005 07:01 PM
Moemers
Nov 7, 2005 05:22 PM
