anyone have this problem?
Old Jan 3, 2003 | 12:37 AM
animated_life's Avatar
Default anyone have this problem?
my passenger side rear strut assembly (on the top of it) has been rattling/gingling for a while and i've been trying everything i can think of to tighten it down and stop it from rattling with no luck. the culprit is the uppermost metal washer gingling between the metal spacer that goes between the two rubber pieces that form the upper bushing, and the lock nut on the top. seems like no matter how tight i tighten that lock nut...the washer still gingles when i hit small imperfections in the road. and it's only that corner...no other corner does it. AND this is a new strut, the old one did it too. should i just put a lock washer between the big upper washer (the gingler) and the lock nut, or what? anyone else had this problem that's willing to admit they're as paranoid about rattling sounds in their car as i am?
Old Jan 3, 2003 | 06:50 AM
IN VTEC's Avatar
Default Re: anyone have this problem? (animated_life)
Try using a 5mm allen wrench to prevent the shock shaft from turning when you tighten the nut.
What kind of springs are you using? -nevermind. H&R Race
[Modified by IN VTEC, 9:51 AM 1/3/2003]
Old Jan 3, 2003 | 10:49 AM
Default Re: anyone have this problem? (IN VTEC)
yeah i know about the allen wrench...that's the only way to tighten down the lock nut. my confusion is that i have already tightened the lock nut down past the marked "safe distance" stated in the documentation that came with the strut. the gingling is just annoying.
hannslebo
Mar 28, 2009 11:12 AM
BMWTN
Sep 2, 2007 01:55 PM
bliss@5200
10
Nov 2, 2006 04:25 PM
komat
15
Dec 20, 2004 05:18 PM
Slow&Furious
Nov 15, 2001 05:42 PM
