Any safe way to remove the airbags?
Re: Any safe way to remove the airbags? (xDantex)
is pretty symple really just remove the 2 screws on the side of the steering wheel and unplug the air bag, it doesn't matter if the battery is hoop up or not
Re: Any safe way to remove the airbags? (LLEO245)
very dangerous...
when doing this you should also check if the air bags have back up power supplys
Re: Any safe way to remove the airbags? (NXLude)
Some airbags take up to 30mins to de-activate after the battery is disconnected, even then you have no idea. Some airbags have capacitors, which will store a charge and set them off randomly! I've seen go off and hit people, not a good thing!
Be careful ie.
Don't sit directly in front of the stearing wheel. Recommend you stay about 10" at least, away from the bag of the steering wheel and 16" away for the passenger airbag.
Never try to block them from going off by putting something over the bag.
You should be fine.
Be careful ie.
You should be fine.
Im shaving a couple hundred punds off the car before my built h22 finds a home. Right now the car is bare metal everywhere, the only thing in it right now is the dash, steering wheel, airbags and ABS/brake units.....I want to lose 300 lbs off of it and am getting clost to that (Ive weighed everything coming out from the seats to the huge pile of sound deadoning tar I scrapped and chisled off the cabin floors).
I figure with a cage and 5 point harness Ill be just as safe as with the bags.....btw its only a play car....
Re: Any safe way to remove the airbags? (Racebred H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racebred H »</TD></TR><TR><TD CLASS="quote">^^^^^^^^^^I hope all you people ar kidding......Airbags need the sensors on the front of the vehicle to tell them to explode.......it wouldnt matter if your battery was disconnected or not....Unless you were sitting in your car taking out the airbag and before u got it unplugged somebody hit you head on then u might be in trouble......</TD></TR></TABLE>
ur obviously retarded. u should watch wat u say before u make a nonsense post. all the sensors connect to the air bag module. theres only 2 wires that come from the air bag module to the actual air bag. its very common to make a mistake and cross the 2 and bammmm. just be careful. unplug the clip before u take em out. the clips are easily accessible even before u start unscreing the air bags.
evan221
06-26-2009 05:10 PM
bquakkel
04-05-2006 04:54 PM
