another VTEC Question!!
Old Apr 23, 2002 | 08:14 PM
00VTEC's Avatar
Default another VTEC Question!!
would VTEC engage if ur running lean or too rich? anyone??
Old Apr 23, 2002 | 08:17 PM
MrFatBooty's Avatar
Default Re: another VTEC Question!! (00VTEC)
Yes.
Old Apr 23, 2002 | 08:54 PM
RC211V's Avatar
Default Re: another VTEC Question!! (MrFatBooty)
what do you mean?
Old Apr 23, 2002 | 08:56 PM
Chris's Avatar
Default Re: another VTEC Question!! (JDMintegGSR)
Conditions of VTEC engagement:
Engine Temp.
Oil Pressure (enough oil)
If those two are met VTEC WILL engage, if one does not pass.. NO VTEC.
yes.. even in reverse.
Old Apr 24, 2002 | 04:52 PM
t's Avatar
t
Default Re: another VTEC Question!! (Chris)
speed
Old Apr 24, 2002 | 05:26 PM
threatcon13's Avatar
New User
Default Re: another VTEC Question!! (t)
speed
speed is irrelevant...as long as youre at 4400 or over it will engage once the two other conditions are met.
Old Apr 24, 2002 | 05:29 PM
harryg's Avatar
throttle
engine temperature
speed
oil pressure
Old Apr 24, 2002 | 06:15 PM
dubster99's Avatar
Default Re: another VTEC Question!! (harrytg)
It doesnt rely on throttle. Common misconception that you must be at WOT for vtec to engage.
Old Apr 24, 2002 | 06:45 PM
Chris's Avatar
Default Re: another VTEC Question!! (dubster99)
so true...
I re-iterate my above post... not to sound like a *****, but that is the end of the discussion.. Anything contrary to what I posted is false, and contributing to spreading more mis-information.
Old Apr 24, 2002 | 06:55 PM
B18 B e a s T's Avatar
throttle
engine temperature
speed
oil pressure
Speed doesn't mean anything, because you could be in neutral revving up and VTEC will still engage.
Yes, a lot of people do think you have to be at wide open throttle for VTEC to engage. Not true. You can be at 5% throttle and VTEC will engage as long as requirements are met.
Old Apr 24, 2002 | 07:14 PM
CivicEx95's Avatar
Default Re: another VTEC Question!! (B18 B e a s T)
Wrong. Try hooking up a VTEC light and see if it comes on when you sit in your driveway and rev. Even says in the Helms manual you need to be going a certain speed. Get the facts straight.
Old Apr 24, 2002 | 07:51 PM
t's Avatar
t
Default Re: another VTEC Question!! (ALLMOTORDC2)
speedspeed is irrelevant...as long as youre at 4400 or over it will engage once the two other conditions are met.
It doesnt engage when your sitting at the tree reving it to 7500rpm for your launch, unless you have a VTEC controller installed.
Old Apr 24, 2002 | 07:56 PM
Chris's Avatar
Default Re: another VTEC Question!! (CivicEx95)
Hmmm.. I sit corrected. I also noticed my rev-limit is lower in neutral...(8K indicated on my R, as opposed to 9K indicated)
502em1
13
Apr 18, 2007 10:53 AM
1JDMDOMINICAN
Mar 20, 2007 02:03 PM
tommymoose
Aug 5, 2004 09:37 PM
Nsane1
Jun 12, 2004 04:47 PM
Keane Rated R
Apr 22, 2002 05:47 AM
