All B-Series Clutches the same?
Old Mar 20, 2009 | 11:59 AM
rdssk8rcs1's Avatar
Default All B-Series Clutches the same?
I have an LS Transmission and I was wondering if a clutch out of a b16 would fit?
Are the splines different? Would it fit under the pressure plate?
Old Mar 20, 2009 | 01:17 PM
mpls's Avatar
Default Re: All B-Series Clutches the same?
90-91 integra is the same
92-01 integras 99-00 civic si is all the same
Old Mar 20, 2009 | 04:04 PM
saelee23's Avatar
^^ same as above 90-91 DA's are different. i'm not sure about the cable b16's
so if you got an 92+ trans your okay
Old Mar 20, 2009 | 04:12 PM
S2Integra's Avatar
All b series with vtech, pending same generation. look at buying options ie toda, spoon, mugen, the clutches are the same for all B series. I think that either S80 or Y80 tranny's are interchangeable
Old Mar 20, 2009 | 06:11 PM
vladd's Avatar
you sure 91 is different from 92? i thought it was 90-93 is different from 94+ because the 90-93 tranny is cable while 94+ is hydro.
Old Mar 20, 2009 | 07:44 PM
TOO MUCH TORQUE's Avatar
when the was the clutch hydraulic system applied to the integra?
Old Mar 20, 2009 | 08:08 PM
vladd's Avatar
94
Old Mar 21, 2009 | 12:12 PM
seanbev24's Avatar
Yeah it has nothing to do with cable or hydro. 90-91 trannies use a smaller input shaft. 92-2001 use the same input shaft, you can even swap hydro internals into the 92-93 cable cases. Also, the only difference between the 90-91 clutches and the 92-01's is the disk, the pressure plate is the same.
Old Mar 21, 2009 | 10:18 PM
connor53's Avatar
match part numbers listed for your application and the one you want from company's like
Competition, ACT, and Exedy. If you're numbers match you're good. If not then no. Just trying to make it quick and easy based on not know EXACTLY what you have.
Old Mar 22, 2009 | 12:00 AM
vladd's Avatar
hm... i've never heard that before. i always thought that the input shaft changed in 94 with the hydrolic tranny.
Old Mar 22, 2009 | 06:26 AM
Mikey361's Avatar
man i dont know that a 92-93 cable clutch, will interchange with a 94 or newer.
Old Mar 22, 2009 | 07:06 AM
be18see1's Avatar
92+ trans are the same. 90-91 are the same. The input shafts differ in diameter. I'm absolutely certain. The clutch used in a 92-93 cable trans is the same as a 94+. Just because the actuator is different doesn't mean that the clutch is different.
Old Mar 22, 2009 | 07:38 AM
Mikey361's Avatar
ok cool, i was under the inpression that the cable clutch was different. good to know
Old Mar 22, 2009 | 07:51 AM
fox1592's Avatar
actually the diameter is the same. the spline count is same just the size of the splines are differenet. i am finishing up a b18b1 swap into my da and that was one of many differences that i ran into. its also recommended to match clutch to whatever tranny you use. i believe your right on the 92-93 trans and clutch statement
Old Mar 22, 2009 | 08:30 AM
4drteg54321's Avatar
good info should be a sticky
Old Mar 22, 2009 | 11:33 AM
Lord Helmet's Avatar
Correct I have the b16 hydro internals in my YS1 cable tranny for my 92 DA. I'm using the 92-93 GSR clutch for it too. Direct bolt on affair
EF9-CIVIC
Jun 6, 2007 04:48 PM
Bizarre
Jul 26, 2006 11:12 AM
Sammex
Nov 13, 2004 01:28 PM
soakit
Jul 9, 2003 02:52 PM
