alingment asap
Old Aug 28, 2001 | 05:06 PM
ondeezracing's Avatar
Default alingment asap
heres my set-up, tokico non-adjustable shocks-neuspeed sport springs-suspension tech sway bars f&r-tower braces f&r, also kumho victoracers 195-14s i need a good starting point on an alingment for autocross any help would be nice, i have to race this weekend, i understand that different people like different things i just need a good starting point to tune from. thanks in advance
Old Aug 28, 2001 | 05:14 PM
Honda318dx's Avatar
Default Re: alingment asap (ondeezracing)
For autox, toe out the front a 1/16" front and rear, no abnormal tire wear.. If you can adjust camber, try for -2 in the front and -1 in the rear..
Old Aug 28, 2001 | 05:42 PM
krshultz's Avatar
What Corey said. It'll make a HUGE difference, and it won't kill your tire wear.
If you want to dial in more rotation, try raising the rear pressures to higher than the fronts. You're effectively giving up grip in the back...but the car will turn better. Understand that high rear tire pressures, along with a good toed-out alignment, will result in a very different car than you might be used to (you'll be surprised).
egfanatic
Jan 23, 2015 07:35 AM
95cx
Suspension & Brakes
Apr 17, 2009 09:21 AM
LX4CYL
Apr 12, 2005 01:17 PM
ghettoracer
34
Aug 5, 2003 09:22 AM
alu95
10
Mar 21, 2003 12:50 PM
