Pulls to the right
Old Sep 5, 2005 | 02:51 PM
AJ21GSR's Avatar
Default Pulls to the right
About a year ago I had been up for and working for about 26 hours... On the way home my friend was sleeping in the passanger seat and I managed to do the same for about half a second... Just long enough to pop my left tire up on the median... Luckly I didn't ruin my gsr wheels, but ever since then, my car pulls drasticly to the right... I had a shop try and fix the alignment and it helped very little. I'm guessing that I need to have something replaced in the suspension system. Any time a part goes out or I need to replace something I like to upgrade. Any thoughts on my suspension, upgrades from stock, and what it is I may need to replace?
Old Sep 5, 2005 | 03:12 PM
sittingonROTAS's Avatar
76.216.10.150
maybe control arm problem? mine use to do that too when i first bought the car cause the lca was bent a little and then i got it replaced with a bunch of new parts and the alignment was still off a little bit but then i got my oil changed and an alignment done at wheel works cause i had coupons and it worked out.
Old Sep 5, 2005 | 03:18 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (sittingonROTAS)
A good alignment shop will tell you which part needs to be replaced. It's most likely the lower control arm as stated.
Old Sep 5, 2005 | 04:55 PM
acuramike's Avatar
Default Re: Pulls to the right (AJ21GSR)
maybe a control arm bushing,tie rod or axle
rbizzell30
Aug 30, 2008 06:21 AM
IgnitionZ05
Mar 18, 2007 09:54 AM
jond
Suspension & Brakes
Aug 29, 2006 03:00 PM
95greenlude
Jul 25, 2005 04:00 PM
94SuperLudeSI
Jul 10, 2005 08:45 PM
